  • 大小: 1.49MB
    下載: 5 次
    發布日期: 2021-04-07
  • 標簽: sqlite??vb??litex_sqlite??
sqlite支持vb6的版本,使用該版本后就能用vb6.0操作sqlite數據庫了,速度比較快,使用前先注冊
**?2004?October?31
**?The?author?disclaims?copyright?to?this?source?code.??In?place?of
**?a?legal?notice?here?is?a?blessing:
**????May?you?do?good?and?not?evil.
**????May?you?find?forgiveness?for?yourself?and?forgive?others.
**????May?you?share?freely?never?taking?more?than?you?give.
**?This?file?contains?the?C?functions?that?implement?blob
**?functions?for?SQLite.??
**?There?is?only?one?exported?symbol?in?this?file?-?the?function
**?sqlite3_register_blob_functions()?found?at?the?bottom?of?the?file.
**?All?other?code?has?file?scope.
#include?“blobfn.h“
#ifdef?_UNICODE
#define?BLOB_CP?SQLITE_UTF16LE
#else
#define?BLOB_CP?SQLITE_UTF8
static?int?get_first_param(?
??sqlite3_context?*context
??int?argc
??sqlite3_value?**argv
??int*?pnSize
??const?char**?ppBlob?)
????if?(?(argc?>?0)?&&
?????????(sqlite3_value_type(argv[0])?==?SQLITE_BLOB?)?)
????????*pnSize?=?sqlite3_value_bytes(?argv[0]?);
????????*ppBlob?=?(const?char*)sqlite3_value_blob(?argv[0]?);
????????return?1;
????else
????????return?0;
static?TCHAR?get_second_param(
??int?argc
??TCHAR?cDef?)
????if?(?(argc?>?1)?&&
?????????(sqlite3_value_bytes(argv[1])>0)?&&
?????????(sqlite3_value_type(argv[1])?==?SQLITE_TEXT?)?)
#ifdef?_UNICODE
????????return?*(?(const?WCHAR*)sqlite3_value_text16le(argv[1])?);
#else
????????return?*sqlite3_value_text(argv[1]);
????else
????????return?cDef;
**?tovis
static?void?tovisFunc(
??int?argc
??sqlite3_value?**argv?)
????int?nSize?i;
????const?char*?pBlob;
????PTSTR?pszRes;
????TCHAR?cRep;
char?c;
????if?(?!get_first_param(?context?argc?argv?&nSize?&pBlob?)?)
????????return;
????cRep?=?get_second_param(?context?argc?argv?_T(‘\0‘)?);
????if?(?!_istprint(cRep)?)?cRep?=?_T(‘.‘);?//?default?value
????pszRes?=?malloc(?nSize?*?sizeof(TCHAR)?);
????if?(?!pszRes?)
????????return;
????for(?i=0;?i????{
????????c?=?pBlob[i];
????????pszRes[i]?=?isprint(c)??c?:?cRep;
#ifdef?_UNICODE
????sqlite3_result_text16le(context?pszRes?nSize?*?sizeof(WCHAR)?SQLITE_TRANSIENT);
#else
????sqlite3_result_text(context?pszRes?nSize?SQLITE_TRANSIENT);
????free(pszRes);
static?const?TCHAR?HEXDIG[]?=?_T(“0123456789ABCDEF“);
**?tohex
static?void?tohexFunc(
??int?argc
????int?nSize?i?j;
????PTSTR?pszRes;
????TCHAR?cSep;
char?c;
????int?nAddSep;
?????目錄???????????0??2006-04-23?18:40??Doc\
?????文件????????1854??2006-04-23?18:39??Doc\ado_dot_net.html
?????文件???????38519??2006-05-12?23:25??Doc\automation.html
?????文件????????1633??2006-04-27?22:35??Doc\index.html
?????文件???????66143??2006-05-12?23:22??Doc\pp.html
?????目錄???????????0??2006-02-18?12:37??Inc\
?????文件??????????57??2006-04-23?17:40??Inc\Readme.txt
?????目錄???????????0??2006-02-18?12:37??Lib\
?????目錄???????????0??2006-04-23?18:59??LibDll\
?????文件???????15268??2006-04-23?17:18??LibDll\sqlite3.exp
?????文件???????25196??2006-04-23?17:18??LibDll\sqlite3.lib
?????文件???????15268??2006-04-23?11:30??LibDll\sqlite3d.exp
?????文件???????25306??2006-04-23?11:30??LibDll\sqlite3d.lib
?????文件???????15274??2006-04-23?11:46??LibDll\sqlite3du.exp
?????文件???????25424??2006-04-23?11:46??LibDll\sqlite3du.lib
?????文件???????15272??2006-04-23?17:18??LibDll\sqlite3u.exp
?????文件???????25306??2006-04-23?17:18??LibDll\sqlite3u.lib
?????目錄???????????0??2006-04-23?17:41??litex\
?????目錄???????????0??2006-05-14?21:40??litex\bin\
?????文件??????????26??2004-08-16?21:07??litex\bin\reg_litex.bat
?????文件??????216064??2006-05-14?21:33??litex\bin\sqlite3.dll
?????文件??????216576??2006-05-14?21:34??litex\bin\sqlite3u.dll
?????文件??????????29??2004-08-16?21:07??litex\bin\ureg_litex.bat
?????文件????????4612??2004-11-03?22:17??litex\blobfn.c
?????文件?????????242??2004-09-28?18:30??litex\blobfn.h
?????文件????????4764??2006-05-14?21:32??litex\Changelog.txt
?????文件????????5535??2006-04-27?21:25??litex\Connection.cpp
?????文件????????2292??2006-04-27?21:22??litex\Connection.h
?????文件?????????831??2004-11-10?17:11??litex\dlldata.c
?????文件????????1161??2004-08-08?08:29??litex\dlldatax.c
?????文件?????????754??2004-08-08?08:29??litex\dlldatax.h
............此處省略127個文件信息
