ezDICOM對于像MRI,CT掃描,和超聲圖像的醫學圖像的觀看者。它可以查看和分析各種格式的醫學圖像,并且可以從專有格式轉換醫學圖像。
using?System.Reflection;
using?System.Runtime.CompilerServices;
//?General?Information?about?an?assembly?is?controlled?through?the?following?
//?set?of?attributes.?Change?these?attribute?values?to?modify?the?information
//?associated?with?an?assembly.
[assembly:?Assemblytitle(“ezDicom?C#“)]
[assembly:?AssemblyDescription(“A?simple?C#?wrapper?for?the?ezDicom?control“)]
[assembly:?AssemblyConfiguration(““)]
[assembly:?AssemblyCompany(““)]
[assembly:?AssemblyProduct(““)]
[assembly:?AssemblyCopyright(““)]
[assembly:?AssemblyTrademark(““)]
[assembly:?AssemblyCulture(““)]
//?Version?information?for?an?assembly?consists?of?the?following?four?values:
//??????Major?Version
//??????Minor?Version?
//??????Build?Number
//??????Revision
//?You?can?specify?all?the?values?or?you?can?default?the?Revision?and?Build?Numbers?
//?by?using?the?‘*‘?as?shown?below:
[assembly:?AssemblyVersion(“1.0.*“)]
//?In?order?to?sign?your?assembly?you?must?specify?a?key?to?use.?Refer?to?the?
//?Microsoft?.NET?framework?documentation?for?more?information?on?assembly?signing.
//?Use?the?attributes?below?to?control?which?key?is?used?for?signing.?
//?Notes:?
//???(*)?If?no?key?is?specified?the?assembly?is?not?signed.
//???(*)?KeyName?refers?to?a?key?that?has?been?installed?in?the?Crypto?Service
//???????Provider?(CSP)?on?your?machine.?KeyFile?refers?to?a?file?which?contains
//???????a?key.
//???(*)?If?the?KeyFile?and?the?KeyName?values?are?both?specified?the?
//???????following?processing?occurs:
//???????(1)?If?the?KeyName?can?be?found?in?the?CSP?that?key?is?used.
//???????(2)?If?the?KeyName?does?not?exist?and?the?KeyFile?does?exist?the?key?
//???????????in?the?KeyFile?is?installed?into?the?CSP?and?used.
//???(*)?In?order?to?create?a?KeyFile?you?can?use?the?sn.exe?(Strong?Name)?utility.
//???????When?specifying?the?KeyFile?the?location?of?the?KeyFile?should?be
//???????relative?to?the?project?output?directory?which?is
//???????%Project?Directory%\obj\.?For?example?if?your?KeyFile?is
//???????located?in?the?project?directory?you?would?specify?the?AssemblyKeyFile?
//???????attribute?as?[assembly:?AssemblyKeyFile(“..\\..\\mykey.snk“)]
//???(*)?Delay?Signing?is?an?advanced?option?-?see?the?Microsoft?.NET?framework
//???????documentation?for?more?information?on?this.
[assembly:?AssemblyDelaySign(false)]
[assembly:?AssemblyKeyFile(““)]
[assembly:?AssemblyKeyName(““)]
?????目錄???????????0??2004-12-02?15:11??executables\dcm2jpg\
?????文件??????218112??2004-12-02?15:07??executables\dcm2jpg\dcm2jpg.exe
?????文件????????2937??2003-05-14?05:00??executables\dcm2jpg\dcm2jpg.txt
?????文件??????176541??2004-04-24?12:53??executables\dcm2jpg\dcm2jpg.zap
?????目錄???????????0??2004-12-02?15:10??executables\StandAlone\
?????文件?????????768??2000-08-26?15:48??executables\StandAlone\BLACKBDY.LUT
?????文件?????????768??2000-11-01?11:46??executables\StandAlone\bone.lut
?????文件?????????768??2000-08-26?15:48??executables\StandAlone\CARDIAC.LUT
?????文件??????274432??2004-12-02?15:06??executables\StandAlone\ezDicom.exe
?????文件?????????768??2000-08-26?15:48??executables\StandAlone\FLOW.LUT
?????文件?????????768??2000-08-26?15:48??executables\StandAlone\GE_color.lut
?????文件?????????768??2000-08-28?17:40??executables\StandAlone\Gold.lut
?????文件?????????768??2001-03-11?07:21??executables\StandAlone\HOTIRON.LUT
?????文件?????????768??2000-08-26?15:47??executables\StandAlone\NIH.lut
?????文件?????????768??2000-08-26?15:48??executables\StandAlone\NIH_fire.lut
?????文件?????????768??2000-08-26?15:47??executables\StandAlone\NIH_ice.lut
?????文件?????????768??2000-09-01?07:16??executables\StandAlone\Rainramp.lut
?????文件?????????768??2000-08-26?15:47??executables\StandAlone\SPECTRUM.LUT
?????文件?????????768??2000-08-26?15:47??executables\StandAlone\X_hot.lut
?????文件?????????768??2000-08-26?15:48??executables\StandAlone\X_rain.lut
?????目錄???????????0??2004-12-02?12:42??source\activex\
?????目錄???????????0??2004-12-02?12:42??source\activex\delphidemo\
?????文件????????3262??2002-11-11?03:44??source\activex\delphidemo\ax.ico
?????文件?????????225??2002-11-11?03:37??source\activex\delphidemo\Project1.dpr
?????文件??????398336??2004-09-30?19:45??source\activex\delphidemo\Project1.exe
?????文件????????3372??2002-11-11?03:45??source\activex\delphidemo\Project1.res
?????文件?????????667??2002-11-11?03:49??source\activex\delphidemo\Readme.txt
............此處省略123個文件信息
