LT8619C_LT8618EXB ,最大支持4k@30, hdmi 輸入轉lvds hdmi轉bt1102 bt656 LT8619C驅動代碼,并且里面有很多的解釋,用法比較簡單,修改里面的宏即可。親測驅動代碼非常好用有效!
* ProjectName: ???LT8522EX
* FileName: ???????lt8522ex.c
* BuildData: ?????2014-03-27
* Version:????????V1.00
*?Company: ???????Lontium
#define???_MAIN_
#include?“Include.h“
//bit?FlagInterrupt;
#ifdef?_LT8619C_
u8 LT8619C_Output_Mode;????//?=?_YUV_Output_;
u8 Refer_Resistance;???????//=?_Internal_;
bit?Load_HDCPKey_En;????????//=?0;//??1:外接?HDCP?key;?0:不使用?HDCP?Key
bit?CLK_DDRMODE_EN;?????????//=?0;?//?1:?CLK?divided?by?2?;?0?:?Normal
u8 Sync_Polarity;??????????//=?_Follow_Input_;
u8 CLK_Polarity;
u8 CP_Convert_Mode;????????//=?HDTV;
u8 Audio_Output_Mode;??????//?=?_IIS_Output_;
bit?Audio_Output_En;????????//?=?1;//?1?:?enable?Audio
bit?Sync_Change;
#ifdef?_YUV_
//?when?LT8619C_Output_Mode?==?_YUV_Output_
u8 YUV_Output_Mode;????????//=?_BT1120_Output_;
u8 YC_swap;????????????????//=?0x08;//?when?BT1120?Output
u8 YUV_ColorDepth;?????????//= _Output_16bit_High_;
//?when?YUV_Output_Mode?==?_BT656_Output_
bit?BT656_Double_CLK_En;????//=?0;?//?后端?BT656?如果是單沿采樣的話需要設置?Double?CLK輸出
bool YUV_DE_Output;
#ifdef?_RGB888_
//?when?LT8619C_Output_Mode?==?_RGB_Output_
u8 TTL_Color_Mode;?????????//=?_Output_3x8bit_;
u8 TTL_Bit_Swap;???????????//=?0x00; //?0x10:?bit24?~?bit0?high/low?bit?swap?enable.?0x00:?Normal
u8 TTL_Output_RGB_Swap;????//=?_OutPut_RGB_;
u8 Red_Bit_Swap;???????????//=?_Red_Bit_Swap_Dis;//?0x20:?Red?bit7?~?bit0?swap?enable;?0x00?:?Normal
u8 Green_Bit_Swap;?????????//=?_Green_Bit_Swap_Dis;//?0x40:?Red?bit7?~?bit0?swap?enable;?0x00?:?Normal
u8 Blue_Bit_Swap;??????????//=?_Blue_Bit_Swap_Dis;//?0x80:?Red?bit7?~?bit0?swap?enable;?0x00?:?Normal
//u8?_6bit_Dither?=?_6bit_Dither_Dis;?//?_6bit_Dither_Dis?:?_Output_3x8bit_
#ifdef?_LVDS_
//?when?LT8619C_Output_Mode?==?_LVDS_Output_
u8 LVDS_Port;??????????????//=?_1_Port_LVDS_;
u8 LVDS_SyncMode;??????????//=?_Sync_Mode_;
u8 LVDS_ColorDeepth;???????//=?_8_bit_ColorDepth_;
u8 LVDS_C_D_Port_Swap;?????//=?_C_D_Port_Swap_Dis;
u8 LVDS_R_B_Color_Swap;????//=?_R_B_Color_Swap_Dis;
u8 LVDS_Map;???????????????//=?_VESA_;
//u8?LVDS_Normal_Output?;//=?1;//
u8 LVDS_Output_En;?????????????//=?_LVDS_Output_En;//?enable?LVDS?output
bit?GPIO13_Read_Status?=?0;
//extern?void?Write_EDID2HDMI_Shadow(void);
#else
//u8 YUV_Output_Mode;
//#ifdef?_N76E003_
bit?LT8619C_IIC_En;
bit?LT8618_IIC_En;
bit?SDA_Ack;
//#endif
#ifdef?_LT8618_
u8 Audio_Input_Mode;???//?=?_IIS_Output_;
bit?Audio_Input_En;?????//?=?1;//?1?:?enable?Audio
u8 LT8618_Input_Mode;
u8 YUV_Input_Mode;
u8 Outp
?????目錄???????????0??2020-02-17?16:42??LT8619C\
?????目錄???????????0??2019-08-06?17:35??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\
?????目錄???????????0??2019-06-11?15:01??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\inc\
?????文件?????????401??2018-03-12?17:25??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\inc\Delay.h
?????文件?????????522??2018-03-20?18:16??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\inc\edid.h
?????文件???????44157??2018-03-20?19:09??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\inc\Function_Define.h
?????文件?????????662??2018-08-30?14:52??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\inc\HDMI_Check.h
?????文件????????1006??2018-03-20?18:08??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\inc\I2C_Master.h
?????文件?????????735??2018-08-21?14:19??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\inc\include.h
?????文件????????6210??2018-09-03?18:47??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\inc\LT8618EXB.h
?????文件???????12536??2018-05-18?14:42??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\inc\LT8619C.h
?????文件????????5003??2019-06-11?15:01??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\inc\main.h
?????文件????????8024??2018-03-20?17:35??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\inc\N76E003.h
?????文件???????48631??2018-03-20?17:15??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\inc\SFR_Macro.h
?????文件?????????856??2018-05-30?15:11??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\inc\type.h
?????文件?????????643??2018-08-20?16:54??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\inc\uart0.h
?????文件??????581632??2017-08-29?09:40??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\LT8911.IAB
?????文件????????6008??2018-03-12?17:01??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\LT8911.IAD
?????文件??????163840??2018-03-12?21:53??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\LT8911.IMB
?????文件????????1928??2018-03-12?21:53??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\LT8911.IMD
?????文件??????????88??2019-07-03?16:13??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\LT8911.PFI
?????文件?????????776??2019-07-03?16:13??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\LT8911.PO
?????文件???????23912??2018-03-12?21:53??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\LT8911.PR
?????文件??????152312??2018-03-12?21:53??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\LT8911.PRI
?????文件?????1160996??2018-03-20?16:19??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\LT8911.PS
?????文件?????????121??2018-09-03?17:45??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\LT8911.SearchResults
?????文件???????28860??2019-07-03?21:16??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\LT8911.WK3
?????文件???????27438??2019-08-06?17:35??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\main.c
?????目錄???????????0??2019-08-06?18:16??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\pro\
?????目錄???????????0??2019-08-06?17:35??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\pro\Listings\
?????文件????????8126??2019-08-06?17:35??LT8619C\LT8619C_LT8618EXB_EVB_HDMI_Converter_20180914_N76E003_PLL_setting_2_Beta\pro\Listings\Delay.lst
............此處省略42個文件信息
