大小: 856KB文件類型: .rar金幣: 2下載: 1 次發布日期: 2021-05-20
- 標簽:
單片機通過DS18b20采集溫度,發送給PC機,PC采用VB編程,VB接收單片機串口輸入畫圖
VB6.0開發上位機程序,有源碼
C51下位機程序有源碼
采集18B20溫度,并傳給上位機,測試通過,絕對好用,全部工程都在文件里面
#define?Key_UP????????????P1_5?
#define?Key_DOWN??????????P1_4???
#define?Key_SET???????????P1_6???
#define?RelayOutPort??????P3_7??
#define?LEDPort???????????P0??????
#define?DELPort???????????P3_6???
#define?LEDTwoC???????????P2_6????
#define?LEDThreeC?????????P2_7????
#define?TMPort ??P3_3
#define?INBUF_LEN?5?//數據長度
unsigned?char?inbuf1[INBUF_LEN]={‘0‘‘0‘‘0‘‘0‘‘0‘};//發送緩沖區
unsigned?char?inbuf2[50];//接收緩沖區
unsigned?char?count3;
void?init_serialcomm(?void?)
SCON?=?0x50?;?//SCON:?serail?mode?1?8-bit?UART?enable?ucvr
TMOD?|=?0x20?;?//TMOD:?timer?1?mode?2?8-bit?reload
PCON?|=?0x80?;?//SMOD=1;
TH1?=?0xFA?;?//Baud:9600?fosc=11.0592MHz
IE?|=?0x90?;?//Enable?Serial?Interrupt
TR1?=?1?;?//?timer?1?run
//向串口發送一個字符
void?send_char_com(?unsigned?char?ch)
SBUF=ch;
while?(TI==?0?);
TI=?0?;
//向串口發送一個字符串,strlen?為該字符串長度
void?send_string_com(?unsigned?char?*str?unsigned?int?strlen)
unsigned?int?k=?0?;
do
send_char_com(*(str?+?k));
k++;
}?while?(k?}
//串口接收中斷函數
void?serial?()?interrupt?4?using?3
if?(RI)?//RI==開始接收
unsigned?char?ch;
RI?=?0?;?//軟件RI=0
ch=SBUF;
if?(ch>?1?)
count3=?0?;
inbuf2[count3]=ch;
else
count3++;
inbuf2[count3]=ch;
unsigned?char?code?LEDDis[]={0xC00xF90xA40xB00x990x920x820xF80x800x900xFF0xBF};?//0-9的LED筆劃0xFF為空0xF7為負號
unsigned?char?dis_8[12]={‘0‘‘1‘‘2‘‘3‘‘4‘‘5‘‘6‘‘7‘‘8‘‘9‘‘?‘‘-‘};
static?unsigned?char?bdata?StateREG; //可位尋址的狀態寄存器
sbit?DS1820ON?=?StateREG^0; ??????????//DS1820是否存在
sbit?SetTF?=?StateREG^1;??????????????//是否是在溫度設置狀態
sbit?KeySETDown?=?StateREG^2;?????????//是否已按過SET鍵標識
sbit?PowTF?=?StateREG^3;??????????????//電源電源標識
sbit?KeyTF?=?StateREG^4; //鍵盤是否允許
//sbit?KeySETDowning?=?StateREG^5; //SET是否正在按下
static?unsigned?char?bdata?TLV?_at_?0x0029;?????????//溫度變量高低位
static?unsigned?char?bdata?THV?_at_?0x0028;
static?signed?char?TMV;???????//轉換后的溫度值
static?unsigned?char?KeyVTempKeyV;??????//鍵值
static?unsigned?char?Second;
static?unsigned?char?flag;
static?signed?char?TMRomV?_at_?0x0027;????//高溫限制
static?signed?char?TMSetV?_at_?0x0026;????//溫度設定值
static?unsigned?char?KSDNum;????//SET鍵連按時的采集次數
static?unsigned?char?IntNumIntNum2IntNum3;????//中斷發生次數,IntNum用于SET長按檢測,IntNum2用于設定狀態時LED閃爍
static?signed?char?LED_OneLED_TwoLED_Three;??//LED的顯示位?LED_One為十位,LED_Two為個位
static?unsigned?char?Sign;?//負號標識
void?main(void)
void?InitDS1820(void);???//定義函數
void?ROMDS1820(void);
void?TMVDS1820(void);
void?TMRDS1820(void);
void?TMWDS1820(void);
void?TMREDS1820(void);
void?TMERDS1820(void);
void?ReadDS1820(void);
void?WriteDS1820(void);
void?Delay_510(void);
void?Delay_110(void);
void?Delay_10ms(void);
void?Delay_4s(void);
void?V2ToV(void);
?DELPort=1;
StateREG?=?0;???//初始化變量
SetTF?=?0;
PowTF?=?0; //關電源
THV?=?0;
TLV?=?0;
TMV?=?0;
KeyV?=?0;
TempKeyV?=?0;
KSDNum?=?0;
IntNum?=?0;
IntNum2?=?0;
In
?????文件??????17068??2007-09-28?16:33??PC與單片機雙向通訊智能溫控程序\上位機VB程序\ALARM1.WAV
?????文件??????14828??2007-09-28?16:33??PC與單片機雙向通訊智能溫控程序\上位機VB程序\ALARM2.WAV
?????文件??????14444??2007-09-28?16:33??PC與單片機雙向通訊智能溫控程序\上位機VB程序\ALARM3.WAV
?????文件???????1516??2007-09-28?16:33??PC與單片機雙向通訊智能溫控程序\上位機VB程序\ALARM4.WAV
?????文件???????8550??2007-09-28?16:33??PC與單片機雙向通訊智能溫控程序\上位機VB程序\ALARM5.WAV
?????文件??????42461??2007-09-28?16:33??PC與單片機雙向通訊智能溫控程序\上位機VB程序\ALARM6.WAV
?????文件??????28558??2007-09-28?16:33??PC與單片機雙向通訊智能溫控程序\上位機VB程序\ALARM7.WAV
?????文件?????209452??2007-09-28?16:34??PC與單片機雙向通訊智能溫控程序\上位機VB程序\ALARM8.WAV
?????文件??????76151??2007-09-28?16:34??PC與單片機雙向通訊智能溫控程序\上位機VB程序\ALARM9.WAV
?????文件??????25364??2007-09-28?16:33??PC與單片機雙向通訊智能溫控程序\上位機VB程序\ba
?????文件??????20524??2007-09-28?16:33??PC與單片機雙向通訊智能溫控程序\上位機VB程序\BEEP1.WAV
?????文件??????31788??2007-09-28?16:34??PC與單片機雙向通訊智能溫控程序\上位機VB程序\BEEP2.WAV
?????文件??????35372??2007-09-28?16:34??PC與單片機雙向通訊智能溫控程序\上位機VB程序\BEEP3.WAV
?????文件???????6092??2007-09-28?16:33??PC與單片機雙向通訊智能溫控程序\上位機VB程序\BEOP.WAV
?????文件???????7092??2007-09-28?16:33??PC與單片機雙向通訊智能溫控程序\上位機VB程序\BLEEP1_S.WAV
?????文件???????4972??2007-09-28?16:33??PC與單片機雙向通訊智能溫控程序\上位機VB程序\BUZZ1.WAV
?????文件??????12460??2007-09-28?16:34??PC與單片機雙向通訊智能溫控程序\上位機VB程序\BUZZ2.WAV
?????文件??????22188??2007-09-28?16:34??PC與單片機雙向通訊智能溫控程序\上位機VB程序\BUZZ3.WAV
?????文件??????21740??2007-09-28?16:34??PC與單片機雙向通訊智能溫控程序\上位機VB程序\BUZZ4.WAV
?????文件??????19948??2007-09-28?16:34??PC與單片機雙向通訊智能溫控程序\上位機VB程序\BUZZ5.WAV
?????文件??????16618??2007-09-28?16:34??PC與單片機雙向通訊智能溫控程序\上位機VB程序\CHOOCHOO.WAV
?????文件???????4926??2001-01-22?18:53??PC與單片機雙向通訊智能溫控程序\上位機VB程序\Cls_linediagram.cls
?????文件???????7347??2007-09-28?16:34??PC與單片機雙向通訊智能溫控程序\上位機VB程序\ENGACK.WAV
?????文件??????56864??2007-09-28?16:34??PC與單片機雙向通訊智能溫控程序\上位機VB程序\FERYHORN.WAV
?????文件??????20106??2010-01-19?15:56??PC與單片機雙向通訊智能溫控程序\上位機VB程序\frmMain.frm
?????文件????????906??2010-01-19?15:56??PC與單片機雙向通訊智能溫控程序\上位機VB程序\frmMain.frx
?????文件?????????20??2010-01-19?15:59??PC與單片機雙向通訊智能溫控程序\上位機VB程序\hifans.ini
?????文件???????6269??2007-09-28?16:34??PC與單片機雙向通訊智能溫控程序\上位機VB程序\HONK.WAV
?????文件??????23276??2007-09-28?16:34??PC與單片機雙向通訊智能溫控程序\上位機VB程序\HOOK1.WAV
............此處省略53個文件信息
