  • 大小: 210KB
    發布日期: 2021-05-19
  • 標簽: vb??學生??管理系統??
vb學生管理系統源代碼 部分代碼 Public UserName As String Public txtSQL As String 'use to store record SQLsentence Public dream As ADODB.Recordset 'use to store record object Public Msgtext As String '用來存放返回信息 Public OK As Boolean ' 'Public db As String Public Sub highlight() With Screen.ActiveForm If (TypeOf .ActiveControl Is TextBox) Then .ActiveControl.SelStart = 0 .ActiveControl.SelLength = Len(.ActiveControl) End If End With End Sub Sub Main() 'Dim Login As New Login 'Login.Show vbModal 'f Not Login.OK Then 'Login Failed so exit app ' End 'End If 'Unload studentmdi ' Set login = New login login.Show End Sub Public Function connectstring() As String connectstring = "Provider=Microsoft.jet.OLEDB.3.51;Data source=f:\schoolgroup\school.mdb" End Function Public Function ExecuteSQL(ByVal SQL As String, Msgstring As String) As ADODB.Recordset Dim cnn As ADODB.Connection Dim rst As ADODB.Recordset Dim sTokens() As String On Error GoTo ExecuteSQL_Error sTokens = Split(SQL) Set cnn = New ADODB.Connection cnn.Open connectstring If InStr("INSERT,DELETE,UPDATE", UCase$(sTokens(0))) Then cnn.ExecuteSQL Msgstring = sTokens(0) & "query successful" Else Set rst = New ADODB.Recordset rst.Open Trim(SQL), cnn, adOpenKeyset, adLockOptimistic Set ExecuteSQL = rst Msgstring = "查詢到" & rst.RecordCount & " 條記錄" End If executeSQL_exit: Set rst = Nothing Set cnn = Nothing Exit Function ExecuteSQL_Error: Msgstring = "查詢錯誤:" & err.Description Resume executeSQL_exit End Function Public Function Testtxt(txt As String) As Boolean If Trim(txt) = "" Then Testtxt = False Else Testtxt = True End If End Function
????.......?????85868??2003-01-05?12:26??學生管理系統\schoolgroup\ADDCLASS.FRM
????.......????????56??2003-01-05?12:26??學生管理系統\schoolgroup\ADDCLASS.FRX
????.......?????22040??2003-01-05?12:26??學生管理系統\schoolgroup\addclasss.frm
????.......????????56??2003-01-05?12:26??學生管理系統\schoolgroup\addclasss.frx
????.......????136075??2003-01-05?12:26??學生管理系統\schoolgroup\addcourse.frm
????.......????????56??2003-01-05?12:26??學生管理系統\schoolgroup\addcourse.frx
????.......????136024??2003-01-05?12:26??學生管理系統\schoolgroup\addcourse2.frm
????.......????????56??2003-01-05?12:26??學生管理系統\schoolgroup\addcourse2.frx
????.......????????56??2003-01-05?12:26??學生管理系統\schoolgroup\addcoursee.frx
????.......?????28845??2003-01-05?12:26??學生管理系統\schoolgroup\addcoutable.frm
????.......???????957??2003-01-05?12:26??學生管理系統\schoolgroup\ADDCOU~2.LOG
????.......???????859??2003-01-05?12:26??學生管理系統\schoolgroup\ADDCOU~3.LOG
????.......?????24711??2003-01-05?12:26??學生管理系統\schoolgroup\addleague.frm
????.......??????1090??2003-01-05?12:26??學生管理系統\schoolgroup\addleague.frx
????.......??????9455??2003-01-05?12:26??學生管理系統\schoolgroup\addonegradecourse.frm
????.......?????38353??2003-01-05?12:26??學生管理系統\schoolgroup\ADDROOM.FRM
????.......????????56??2003-01-05?12:26??學生管理系統\schoolgroup\ADDROOM.FRX
????.......?????49583??2003-01-05?12:26??學生管理系統\schoolgroup\ADDROOM1.FRM
????.......????????56??2003-01-05?12:26??學生管理系統\schoolgroup\ADDROOM1.FRX
????.......?????38637??2003-01-05?12:26??學生管理系統\schoolgroup\addroom1frm.frm
????.......????????56??2003-01-05?12:26??學生管理系統\schoolgroup\addroom1frm.frx
????.......?????38423??2003-01-05?12:26??學生管理系統\schoolgroup\addroomfrm.frm
????.......????????56??2003-01-05?12:26??學生管理系統\schoolgroup\addroomfrm.frx
????.......?????34997??2003-01-05?12:26??學生管理系統\schoolgroup\ADDSCORE.FRM
????.......??????1090??2003-01-05?12:26??學生管理系統\schoolgroup\ADDSCORE.FRX
????.......?????31172??2003-01-05?12:26??學生管理系統\schoolgroup\addscoree.frm
????.......??????1090??2003-01-05?12:26??學生管理系統\schoolgroup\addscoree.frx
????.......?????42316??2003-01-05?12:26??學生管理系統\schoolgroup\ADDSTUD.FRM
????.......????????84??2003-01-05?12:26??學生管理系統\schoolgroup\ADDSTUD.FRX
????.......?????13543??2003-01-05?12:26??學生管理系統\schoolgroup\addstudbad.frm
............此處省略90個文件信息
