本光盤(pán)是《AutoCAD 工程師案頭書(shū)》系列中以下三本書(shū)的配套光盤(pán):
? AutoCAD LISP/VLISP 函數(shù)庫(kù)查詢辭典
? AutoCAD VBA 函數(shù)庫(kù)查詢辭典
? AutoCAD ARX 函數(shù)庫(kù)查詢辭典
光盤(pán)中含有三個(gè)目錄:
AutoLisp Vlisp 函數(shù), AutoCAD VBA屬性和AutoCAD ARX函數(shù)。
? AutoLisp Vlisp 函數(shù)目錄對(duì)應(yīng)《AutoCAD LISP/VLISP 函數(shù)庫(kù)查詢辭典》,其中有一個(gè)文件名為AutoLisp Vlisp 函數(shù).chm的文件,為書(shū)的內(nèi)容補(bǔ)充。
? AutoCAD VBA屬性目錄對(duì)應(yīng)《AutoCAD VBA 函數(shù)庫(kù)查詢辭
#include??
#include??
void?initApp();?
void?unloadApp();?
void?helloWorld();?
void?initApp()
????//?register?a?command?with?the?AutoCAD?command?mechanism
????acedRegCmds->addCommand(“HELLOWORLD_COMMANDS“
????????????????????????????“Hello“
????????????????????????????“Bonjour“
????????????????????????????ACRX_CMD_TRANSPARENT
????????????????????????????helloWorld);
void?unloadApp()
????acedRegCmds->removeGroup(“HELLOWORLD_COMMANDS“);
void?helloWorld()
????double?RadiusDiameter;
Diameter=150;
Radius=Diameter/3;
acedCommand(RTSTR?“CIRCLE“RTSTR“100100“RTREALRadius0);
acutPrintf(“\nHello?World!“);
extern?“C“?AcRx::AppRetCode?
acrxEntryPoint(AcRx::AppMsgCode?msg?void*?pkt)
????switch?(msg)?
????????case?AcRx::kInitAppMsg:
????????????acrxDynamiclinker->unlockApplication(pkt);
????????????acrxRegisterAppMDIAware(pkt);
????????????initApp();
????????????break;
????????case?AcRx::kUnloadAppMsg:
????????????unloadApp();
????????????break;
????????default:
????????????break;
????return?AcRx::kRetOK;
?????文件????3305943??2003-03-30?21:22??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\ARX\ob
?????目錄??????????0??2010-06-03?11:06??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\ARX
?????文件?????221234??2003-02-14?14:29??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\sample\hello\Debug\hello.arx
?????文件????????744??2003-02-14?14:29??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\sample\hello\Debug\hello.exp
?????文件?????301180??2003-02-14?14:29??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\sample\hello\Debug\hello.ilk
?????文件???????1734??2003-02-14?14:29??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\sample\hello\Debug\hello.lib
?????文件??????21416??2003-02-14?14:29??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\sample\hello\Debug\Hello.obj
?????文件????4456632??2003-02-14?14:29??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\sample\hello\Debug\hello.pch
?????文件?????623616??2003-02-14?14:29??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\sample\hello\Debug\hello.pdb
?????文件?????230400??2003-02-14?14:29??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\sample\hello\Debug\vc60.idb
?????文件?????217088??2003-02-14?14:29??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\sample\hello\Debug\vc60.pdb
?????目錄??????????0??2010-06-03?11:06??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\sample\hello\Debug
?????文件???????1151??2003-02-14?13:09??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\sample\hello\Hello.cpp
?????文件?????????85??2003-02-14?11:55??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\sample\hello\Hello.def
?????文件???????4247??2003-02-14?14:54??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\sample\hello\hello.dsp
?????文件????????533??2003-02-14?11:45??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\sample\hello\hello.dsw
?????文件??????33792??2003-02-14?14:54??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\sample\hello\hello.ncb
?????文件??????57856??2003-02-14?14:54??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\sample\hello\hello.opt
?????文件???????1411??2003-02-14?14:29??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?ARX函數(shù)\sample\hello\hello.plg
?????文件?????825779??2003-03-26?11:54??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?VBA屬性\AutoCAD?VBA屬性.chm
?????目錄??????????0??2010-06-03?11:06??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoCAD?VBA屬性
?????文件????1841530??2003-03-25?17:57??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoLisp?Vlisp?函數(shù)\AutoLisp?Vlisp?函數(shù).chm
?????目錄??????????0??2010-06-03?11:06??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\AutoLisp?Vlisp?函數(shù)
?????文件??????27136??2003-04-01?17:36??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典\光盤(pán)使用指導(dǎo).doc
?????目錄??????????0??2010-06-06?10:37??AutoCAD?VLISP、VBA、ARX函數(shù)庫(kù)查詢辭典
?????????????12173507????????????????????28
............此處省略1個(gè)文件信息
