  • 大小: 0.49M
    發(fā)布日期: 2021-03-28
  • 標(biāo)簽: vb??
運(yùn)動(dòng)控制板VB6.0,labview代碼,包括:定長,回零,IO測試,直線插補(bǔ)等功能。
?????文件??????71580??2015-01-07?08:51??DMC1000B-Labview\Demo1_Pmove.vi
?????文件??????51306??2015-01-07?08:51??DMC1000B-Labview\Demo2_HomeMove.vi
?????文件??????98304??2015-01-07?08:51??DMC1000B-Labview\Dmc1000.dll
?????文件?????537837??2015-01-07?08:51??DMC1000B-Labview\DMC1000B.llb
?????文件??????70328??2015-01-07?08:51??DMC1000B-Labview\Labview\Demo.vi
?????文件??????70328??2015-01-07?08:51??DMC1000B-Labview\Labview\Demo1.vi
?????文件???????6407??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\Dmc1000.lvlib
?????文件???????1012??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\Report.html
?????文件???????7733??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?board?close.vi
?????文件???????7708??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?board?init.vi
?????文件???????9402??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?change?speed.vi
?????文件???????8600??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?check?done.vi
?????文件???????8548??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?decel?stop.vi
?????文件???????8673??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?get?axis?status.vi
?????文件???????8605??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?get?command?pos.vi
?????文件???????8604??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?get?outbit.vi
?????文件??????10067??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?get?s?profile.vi
?????文件???????8539??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?get?speed.vi
?????文件??????10739??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?home?move.vi
?????文件???????8696??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?immediate?stop.vi
?????文件???????8504??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?in?bit.vi
?????文件???????8487??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?in?enable.vi
?????文件???????9245??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?out?bit.vi
?????文件???????8537??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?Read?D?Word.vi
?????文件???????9393??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?set?command?pos.vi
?????文件???????9413??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?set?pls?outmode.vi
?????文件???????9427??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?set?s?profile.vi
?????文件???????9268??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?set?sd.vi
?????文件??????11490??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?start?s?move.vi
?????文件??????11503??2015-01-07?08:51??DMC1000B-Labview\Labview\函數(shù)庫\Dmc1000\VIs\d1000?start?sa?move.vi
............此處省略42個(gè)文件信息
