Socket 客戶端與服務端對話工具
核心代碼:
Private Sub RunServer()
        Dim ConClient As Socket
        Dim strClientName As String = ""
        Dim bCExist As Boolean    '客戶端是否已經在列表中
        Dim ClientIpEP As IPEndPoint
        Dim CNetWorkStream As NetworkStream
        Dim Reader As BinaryReader
        Do
            bCExist = False
            ConClient = CTcpListener.AcceptSocket    '接收客戶端的連接,返回一個socket
            SentButton.Enabled = True
            Try
                ClientIpEP = CType(ConClient.RemoteEndPoint, IPEndPoint) '獲取socket的ipendpoint
                strClientName = Dns.GetHostEntry(ClientIpEP.Address).HostName  '獲取客戶端的名稱
            Catch ex As SocketException
                ClientIpEP = Nothing
                MessageBox.Show(ex.Message)
                Continue Do
            End Try
            '檢測該客戶端是否已在列表中
            Dim strName As String = ""
            For Each strName In ClientListBox.Items
                If String.Compare(strClientName, strName) = 0 Then
                    bCExist = True
                    'Exit For '存在則退出查找
                End If
            Next
            ' 客戶列表中添加客戶
            If bCExist = False Then
                ClientListBox.Items.Add(strClientName)
                HistoryRichText.SelectionColor = Color.Green
                HistoryRichText.AppendText(strClientName & " 加入會話" & vbCrLf)
                HistoryRichText.ScrollToCaret()
                Continue Do
            End If
            Try
                CNetWorkStream = New NetworkStream(ConClient)
                Reader = New BinaryReader(CNetWorkStream)
                HistoryRichText.SelectionColor = Color.Blue
                HistoryRichText.AppendText(strClientName & "說" & vbCrLf)
                HistoryRichText.SelectionColor = Color.Black
                HistoryRichText.AppendText(Reader.ReadString() & vbCrLf)
            Catch ex As Exception
                MsgBox(ex.Message)
            Finally
                CNetWorkStream = Nothing
                Reader = Nothing
            End Try
            ConClient.Disconnect(True) ' 關閉套接字
        Loop
        System.Environment.Exit(System.Environment.ExitCode)
    End Sub
?????文件??????90624??2015-10-26?14:46??ChartClient\Chart\bin\Debug\Chart.exe
?????文件??????38400??2015-10-26?14:46??ChartClient\Chart\bin\Debug\Chart.pdb
?????文件??????11608??2015-10-26?14:48??ChartClient\Chart\bin\Debug\Chart.vshost.exe
?????文件????????490??2010-03-17?22:39??ChartClient\Chart\bin\Debug\Chart.vshost.exe.manifest
?????文件????????620??2015-10-26?14:46??ChartClient\Chart\bin\Debug\Chart.xml
?????文件???????6286??2015-10-21?17:18??ChartClient\Chart\Chart.vbproj
?????文件????????478??2015-10-21?17:18??ChartClient\Chart\Chart.vbproj.user
?????文件???????4510??2015-10-26?14:46??ChartClient\Chart\frmChartclient.Designer.vb
?????文件???????5814??2015-10-26?14:46??ChartClient\Chart\frmChartclient.resx
?????文件???????6068??2015-10-26?14:46??ChartClient\Chart\frmChartclient.vb
?????文件???????1568??2015-10-21?17:18??ChartClient\Chart\My?Project\Application.Designer.vb
?????文件????????478??2012-08-27?06:58??ChartClient\Chart\My?Project\Application.myapp
?????文件???????1099??2012-08-27?06:58??ChartClient\Chart\My?Project\AssemblyInfo.vb
?????文件???????3070??2015-10-21?17:18??ChartClient\Chart\My?Project\Resources.Designer.vb
?????文件???????6199??2012-08-27?06:58??ChartClient\Chart\My?Project\Resources.resx
?????文件???????2984??2015-10-21?17:18??ChartClient\Chart\My?Project\Settings.Designer.vb
?????文件????????279??2012-08-27?06:58??ChartClient\Chart\My?Project\Settings.settings
?????文件????????294??2012-08-27?06:58??ChartClient\Chart\obj\Chart.vbproj.FileList.txt
?????文件??????90624??2015-10-26?14:46??ChartClient\Chart\obj\Debug\Chart.exe
?????文件????????180??2015-10-26?14:46??ChartClient\Chart\obj\Debug\Chart.frmChartclient.resources
?????文件??????38400??2015-10-26?14:46??ChartClient\Chart\obj\Debug\Chart.pdb
?????文件??????68150??2015-10-21?17:23??ChartClient\Chart\obj\Debug\Chart.Resources.resources
?????文件????????891??2015-10-26?14:48??ChartClient\Chart\obj\Debug\Chart.vbproj.FileListAbsolute.txt
?????文件???????1019??2012-08-27?06:58??ChartClient\Chart\obj\Debug\Chart.vbproj.GenerateResource.Cache
?????文件????????620??2015-10-26?14:46??ChartClient\Chart\obj\Debug\Chart.xml
?????文件???????5440??2015-10-26?14:46??ChartClient\Chart\obj\Debug\DesignTimeResolveAssemblyReferencesInput.cache
?????文件???????3698??2015-10-26?14:46??ChartClient\Chart\obj\Debug\ResGen.read.1.tlog
?????文件???????1020??2015-10-26?14:46??ChartClient\Chart\obj\Debug\ResGen.write.1.tlog
?????文件???????7680??2015-10-21?17:18??ChartClient\Chart\obj\Debug\TempPE\My?Project.Resources.Designer.vb.dll
............此處省略58個文件信息
