Media Gateway 用于監控車載以太網通信,以太網端口測試,CAN/LIN/Flexray與100Base-T1路由測試等;在BMW,AUDI,BOSCH以及國內多公司大量使用; MediaGateway from Technica Engineering is a development tool for testing and analyzing on-board vehicle networks. MediaGateway from Technica Engineering is the most widely used development and testing tool for on-board vehicle networks using 100BASE-T1. It’s in-built automotive switches and 12 x 100BASE-T1 ports enable both capture of traffic between devices while maintaining the normal communication, as well as interaction with such devices via your test set-up. It supports single and double tagging of VLANs, Mirroring, Forwarding and more. MediaGateway is excellently suitable for subsystem testing stations and can also be installed in a test vehicle without complications. It is configured conveniently via a browser through the integrated web server. An additional and optional CAN-Ethernet bi-directional conversion is available, as well as FlexRay logging via Ethernet and one SFP slot. The SFP slot supports commercial-grade SFP modules (e.g. optical or RJ-45) as well as our 100BASE-T1 SFP Module in order to get a 13th Automotive Ethernet Port or our 1000BASE-T1 SFP Module – this makes the MediaGateway ready for Automotive Gigabit Ethernet! 12 Broadcom 100BASE-T1 ports (100 MBit/s full duplex on a single unshielded twisted pair) 3 Gigabit Ethernet ports 1 SFP Gigabit Ethernet port Automotive Tyco MQS connectors for 100BASE-T1 and power supply Web server for easy configuration: Master/Slave, HalfOut/FullOut, Port Forwarding, Port Mirroring, VLAN Tagging WakeUp function by CAN Bus or Wakeline Power output for attached devices: VBAT max. 1 Ampere in total 19 status LEDs Possibility to reset to default settings by pushbutton Robust steel case Power requirement: 8 to 16 V DC, power consumption: 8 Watt Size: 195 x 143 x 33 mm 802.1AS Bridge function
