  • 大小: 1.41MB
    發(fā)布日期: 2023-11-03
  • 標(biāo)簽: QT??播放器??rmvb??mp4??mp3??
用QT5開發(fā)的媒體播放器,界面美觀,可以播放rmvb、mp4等視頻格式文件,也可以播放mp3、wav等音頻格式文件,代碼具備一定參考價(jià)值!
**?meta?object?code?from?reading?C++?file?‘mainwindow.h‘
**?Created?by:?The?Qt?meta?object?Compiler?version?67?(Qt?5.6.2)
**?WARNING!?All?changes?made?in?this?file?will?be?lost!
#include?“../../mediaplayer/mainwindow.h“
#include?tatype.h>
#if?!defined(Q_MOC_OUTPUT_REVISION)
#error?“The?header?file?‘mainwindow.h‘?doesn‘t?include?ject>.“
#elif?Q_MOC_OUTPUT_REVISION?!=?67
#error?“This?file?was?generated?using?the?moc?from?5.6.2.?It“
#error?“cannot?be?used?with?the?include?files?from?this?version?of?Qt.“
#error?“(The?moc?has?changed?too?much.)“
QT_BEGIN_MOC_NAMESPACE
struct?qt_meta_stringdata_MainWindow_t?{
????QByteArrayData?data[34];
????char?stringdata0[387];
#define?QT_MOC_LITERAL(idx?ofs?len)?\
????Q_STATIC_BYTE_ARRAY_DATA_HEADER_INITIALIZER_WITH_OFFSET(len?\
????qptrdiff(offsetof(qt_meta_stringdata_MainWindow_t?stringdata0)?+?ofs?\
????????-?idx?*?sizeof(QByteArrayData))?\
static?const?qt_meta_stringdata_MainWindow_t?qt_meta_stringdata_MainWindow?=?{
QT_MOC_LITERAL(0?0?10)?//?“MainWindow“
QT_MOC_LITERAL(1?11?4)?//?“jump“
QT_MOC_LITERAL(2?16?0)?//?““
QT_MOC_LITERAL(3?17?5)?//?“index“
QT_MOC_LITERAL(4?23?4)?//?“seek“
QT_MOC_LITERAL(5?28?7)?//?“seconds“
QT_MOC_LITERAL(6?36?4)?//?“open“
QT_MOC_LITERAL(7?41?4)?//?“stop“
QT_MOC_LITERAL(8?46?8)?//?“previous“
QT_MOC_LITERAL(9?55?4)?//?“play“
QT_MOC_LITERAL(10?60?5)?//?“pause“
QT_MOC_LITERAL(11?66?4)?//?“next“
QT_MOC_LITERAL(12?71?10)?//?“changeMute“
QT_MOC_LITERAL(13?82?12)?//?“changeVolume“
QT_MOC_LITERAL(14?95?6)?//?“volume“
QT_MOC_LITERAL(15?102?10)?//?“changeRate“
QT_MOC_LITERAL(16?113?4)?//?“rate“
QT_MOC_LITERAL(17?118?15)?//?“showColorDialog“
QT_MOC_LITERAL(18?134?18)?//?“mediaStatusChanged“
QT_MOC_LITERAL(19?153?25)?//?“QMediaPlayer::MediaStatus“
QT_MOC_LITERAL(20?179?6)?//?“status“
QT_MOC_LITERAL(21?186?12)?//?“stateChanged“
QT_MOC_LITERAL(22?199?19)?//?“QMediaPlayer::State“
QT_MOC_LITERAL(23?219?5)?//?“state“
QT_MOC_LITERAL(24?225?15)?//?“durationchanged“
QT_MOC_LITERAL(25?241?8)?//?“duration“
QT_MOC_LITERAL(26?250?15)?//?“positionchanged“
QT_MOC_LITERAL(27?266?8)?//?“progress“
QT_MOC_LITERAL(28?275?21)?//?“videoAvailableChanged“
QT_MOC_LITERAL(29?297?15)?//?“metaDataChanged“
QT_MOC_LITERAL(30?313?19)?//?“displayerrorMessage“
QT_MOC_LITERAL(31?333?17)?//?“bufferingProgress“
QT_MOC_LITERAL(32?351?23)?//?“playlistPositionchanged“
QT_MOC_LITERAL(33?375?11)?//?“currentItem“
????“MainWindow\0jump\0\0index\0seek\0seconds\0“
????“open\0stop\0previous\0play\0pause\0next\0“
????“changeMute\0changeVolume\0volume\0“
????“changeRate\0rate\0showColorDialog\0“
????“mediaStatusChanged\0QMediaPlayer:
?????目錄???????????0??2017-09-26?20:01??media_ui\
?????目錄???????????0??2017-09-21?13:47??media_ui\build-mediaplayer-Desktop_Qt_5_6_2_MinGW_32bit-Debug\
?????目錄???????????0??2017-10-11?13:20??media_ui\build-mediaplayer-Desktop_Qt_5_6_2_MinGW_32bit-Debug\debug\
?????文件??????516974??2017-09-27?15:25??media_ui\build-mediaplayer-Desktop_Qt_5_6_2_MinGW_32bit-Debug\debug\main.o
?????文件??????649830??2017-10-11?13:20??media_ui\build-mediaplayer-Desktop_Qt_5_6_2_MinGW_32bit-Debug\debug\mainwindow.o
?????文件?????2305832??2017-10-11?13:20??media_ui\build-mediaplayer-Desktop_Qt_5_6_2_MinGW_32bit-Debug\debug\mediaplayer.exe
?????文件????????9084??2017-09-27?15:25??media_ui\build-mediaplayer-Desktop_Qt_5_6_2_MinGW_32bit-Debug\debug\moc_mainwindow.cpp
?????文件??????520429??2017-09-27?15:25??media_ui\build-mediaplayer-Desktop_Qt_5_6_2_MinGW_32bit-Debug\debug\moc_mainwindow.o
?????文件????????2790??2017-09-27?15:25??media_ui\build-mediaplayer-Desktop_Qt_5_6_2_MinGW_32bit-Debug\debug\moc_myvideowidget.cpp
?????文件??????261258??2017-09-27?15:25??media_ui\build-mediaplayer-Desktop_Qt_5_6_2_MinGW_32bit-Debug\debug\moc_myvideowidget.o
?????文件??????495569??2017-09-27?15:25??media_ui\build-mediaplayer-Desktop_Qt_5_6_2_MinGW_32bit-Debug\debug\myvideowidget.o
?????文件???????22331??2017-09-26?11:24??media_ui\build-mediaplayer-Desktop_Qt_5_6_2_MinGW_32bit-Debug\Makefile
?????文件???????62309??2017-09-26?11:24??media_ui\build-mediaplayer-Desktop_Qt_5_6_2_MinGW_32bit-Debug\Makefile.Debug
?????文件???????62400??2017-09-26?11:24??media_ui\build-mediaplayer-Desktop_Qt_5_6_2_MinGW_32bit-Debug\Makefile.Release
?????目錄???????????0??2017-09-21?13:47??media_ui\build-mediaplayer-Desktop_Qt_5_6_2_MinGW_32bit-Debug\release\
?????文件????????5999??2017-09-26?15:35??media_ui\build-mediaplayer-Desktop_Qt_5_6_2_MinGW_32bit-Debug\ui_mainwindow.h
?????目錄???????????0??2017-10-11?13:26??media_ui\mediaplayer\
?????目錄???????????0??2017-09-26?20:01??media_ui\mediaplayer.bak\
?????文件?????????183??2017-09-21?13:47??media_ui\mediaplayer.bak\main.cpp
?????文件???????10794??2017-09-26?19:59??media_ui\mediaplayer.bak\mainwindow.cpp
?????文件????????1511??2017-09-26?19:58??media_ui\mediaplayer.bak\mainwindow.h
?????文件????????4817??2017-09-26?15:34??media_ui\mediaplayer.bak\mainwindow.ui
?????文件?????????525??2017-09-26?11:24??media_ui\mediaplayer.bak\mediaplayer.pro
?????文件???????23874??2017-09-26?20:01??media_ui\mediaplayer.bak\mediaplayer.pro.user
?????文件????????3255??2017-09-26?19:41??media_ui\mediaplayer.bak\myvideowidget.cpp
?????文件????????2523??2017-09-26?19:13??media_ui\mediaplayer.bak\myvideowidget.h
?????文件?????????183??2017-09-21?13:47??media_ui\mediaplayer\main.cpp
?????文件???????18393??2017-10-11?13:20??media_ui\mediaplayer\mainwindow.cpp
?????文件????????2833??2017-09-27?15:22??media_ui\mediaplayer\mainwindow.h
?????文件????????4817??2017-09-26?15:34??media_ui\mediaplayer\mainwindow.ui
?????文件?????????525??2017-09-26?11:24??media_ui\mediaplayer\mediaplayer.pro
............此處省略3個(gè)文件信息
