內含大量各種曲線圖、餅圖、柱狀圖代碼示例,適合VB.NET初學者,VS2010中可用
using?System.Reflection;
using?System.Runtime.CompilerServices;
//?General?Information?about?an?assembly?is?controlled?through?the?following?
//?set?of?attributes.?Change?these?attribute?values?to?modify?the?information
//?associated?with?an?assembly.
[assembly:?Assemblytitle(““)]
[assembly:?AssemblyDescription(““)]
[assembly:?AssemblyConfiguration(““)]
[assembly:?AssemblyCompany(““)]
[assembly:?AssemblyProduct(““)]
[assembly:?AssemblyCopyright(““)]
[assembly:?AssemblyTrademark(““)]
[assembly:?AssemblyCulture(““)]
//?Version?information?for?an?assembly?consists?of?the?following?four?values:
//??????Major?Version
//??????Minor?Version?
//??????Build?Number
//??????Revision
//?You?can?specify?all?the?values?or?you?can?default?the?Revision?and?Build?Numbers?
//?by?using?the?‘*‘?as?shown?below:
[assembly:?AssemblyVersion(“1.0.*“)]
//?In?order?to?sign?your?assembly?you?must?specify?a?key?to?use.?Refer?to?the?
//?Microsoft?.NET?framework?documentation?for?more?information?on?assembly?signing.
//?Use?the?attributes?below?to?control?which?key?is?used?for?signing.?
//?Notes:?
//???(*)?If?no?key?is?specified?the?assembly?is?not?signed.
//???(*)?KeyName?refers?to?a?key?that?has?been?installed?in?the?Crypto?Service
//???????Provider?(CSP)?on?your?machine.?KeyFile?refers?to?a?file?which?contains
//???????a?key.
//???(*)?If?the?KeyFile?and?the?KeyName?values?are?both?specified?the?
//???????following?processing?occurs:
//???????(1)?If?the?KeyName?can?be?found?in?the?CSP?that?key?is?used.
//???????(2)?If?the?KeyName?does?not?exist?and?the?KeyFile?does?exist?the?key?
//???????????in?the?KeyFile?is?installed?into?the?CSP?and?used.
//???(*)?In?order?to?create?a?KeyFile?you?can?use?the?sn.exe?(Strong?Name)?utility.
//???????When?specifying?the?KeyFile?the?location?of?the?KeyFile?should?be
//???????relative?to?the?project?output?directory?which?is
//???????%Project?Directory%\obj\.?For?example?if?your?KeyFile?is
//???????located?in?the?project?directory?you?would?specify?the?AssemblyKeyFile?
//???????attribute?as?[assembly:?AssemblyKeyFile(“..\\..\\mykey.snk“)]
//???(*)?Delay?Signing?is?an?advanced?option?-?see?the?Microsoft?.NET?framework
//???????documentation?for?more?information?on?this.
[assembly:?AssemblyDelaySign(false)]
[assembly:?AssemblyKeyFile(““)]
[assembly:?AssemblyKeyName(““)]
?????目錄???????????0??2012-05-22?16:30??VB.NET畫圖示例\
?????目錄???????????0??2012-05-22?16:30??VB.NET畫圖示例\af\
?????文件????????3584??2014-08-26?11:24??VB.NET畫圖示例\af\WinFormsChartSamples.resources.dll
?????文件?????????144??2010-01-20?11:33??VB.NET畫圖示例\app.config
?????文件????????4710??2009-04-23?10:19??VB.NET畫圖示例\App.ico
?????文件????????2426??2009-04-23?10:19??VB.NET畫圖示例\AssemblyInfo.cs
?????目錄???????????0??2012-05-22?16:30??VB.NET畫圖示例\ChartAppearance\
?????目錄???????????0??2012-05-22?16:30??VB.NET畫圖示例\ChartAppearance\AntiAliasingSample\
?????文件???????21228??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\AntiAliasingSample\AntiAliasingSample.cs
?????文件????????5814??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\AntiAliasingSample\AntiAliasingSample.resx
?????文件?????????198??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\AntiAliasingSample\cscode.txt
?????文件?????????607??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\AntiAliasingSample\sampleConfig.xml
?????文件?????????195??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\AntiAliasingSample\vbcode.txt
?????目錄???????????0??2012-05-22?16:30??VB.NET畫圖示例\ChartAppearance\Appearance\
?????文件???????30879??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\Appearance\ChartAppearance.cs
?????文件????????5814??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\Appearance\ChartAppearance.resx
?????文件?????????751??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\Appearance\cscode.txt
?????文件?????????732??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\Appearance\Flag.gif
?????文件?????????530??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\Appearance\sampleConfig.xml
?????文件?????????730??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\Appearance\vbcode.txt
?????目錄???????????0??2012-05-22?16:30??VB.NET畫圖示例\ChartAppearance\Borders\
?????文件???????28904??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\Borders\Borders.cs
?????文件????????5814??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\Borders\Borders.resx
?????文件?????????687??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\Borders\cscode.txt
?????文件?????????558??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\Borders\sampleConfig.xml
?????文件?????????209??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\Borders\TOCNodes.xml
?????文件?????????675??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\Borders\vbcode.txt
?????文件?????????144??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\TOCNodes.xml
?????目錄???????????0??2012-05-22?16:30??VB.NET畫圖示例\ChartAppearance\UsingGaps3D\
?????文件?????????428??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\UsingGaps3D\cscode.txt
?????文件?????????557??2009-04-23?10:19??VB.NET畫圖示例\ChartAppearance\UsingGaps3D\sampleConfig.xml
............此處省略1756個文件信息
