  • 大小: 1.27MB
    發布日期: 2023-09-20
  • 標簽: 16x32led??
16x32LED點陣屏74hc154和595.內含仿真,原理圖,VB上位機
//32*16點陣屏//
//作者:潘果
//日期:2013.04.28
//晶振:12MHZ
//包含頭文件
//定義引腳
sbit?K1?=?P1^0;
sbit?K2?=?P1^1;
sbit?K3?=?P1^2;
sbit?K4?=?P1^3;
sbit?K5?=?P1^4;
sbit?K6?=?P1^5;
sbit?en?=?P2^4;
sbit?st?=?P3^5;
sbit?sh?=?P3^6;
sbit?dat?=?P3^7;
//宏定義
typedef?unsigned?char?uchar;
typedef?unsigned?int?uint;
//全局變量
uchar?speed?=?5; //滾動速度控制,值越小速度越大
uchar?DisplayMode?=?4;? //顯示模式選擇
//顯示內容
uchar?code?display[][32]={
0x000x000x000x000x000x000x000x000x000x000x000x000x000x000x000x00
/*--??文字:??歡??--*/
/*--??宋體12;??此字體下對應的點陣為:寬x高=16x16???--*/
0x000x800x000x800xFC0x800x040xFC0x050x040x490x080x2A0x400x140x40
0x100x400x280xA00x240xA00x450x100x810x100x020x080x040x040x080x02
/*--??文字:??迎??--*/
0x000x000x200x800x130x3C0x120x240x020x240x020x240xF20x240x120x24
0x120x240x120xB40x130x280x120x200x100x200x280x200x470xFE0x000x00
/*--??文字:??驗??--*/
0x000x200xF80x200x080x500x480x500x480x880x490x040x4A0xFA0x7C0x00
0x040x440x040x240x1D0x240xE40xA80x440x880x040x100x2B0xFE0x100x00
/*--??文字:??收??--*/
0x080x400x080x400x480x400x480x800x480xFE0x490x080x4A0x880x480x88
0x480x880x580x500x680x500x480x200x080x500x080x880x090x040x0A0x02
/*--??文字:??潘???-*/
0x000x3C0x470xC00x320x480x110x500x8F0xFE0x610x500x220x480x0C0x44
0x170xFE0x240x440xE40x440x270xFC0x240x440x240x440x270xFC0x240x04
/*--??文字:??果???-*/
0x000x100x1F0xF80x110x100x110x100x1F0xF00x110x100x110x100x1F0xF0
0x010x040xFF0xFE0x030x800x050x400x090x200x110x1C0x610x080x010x00
/*--??文字:??的??--*/
0x100x400x100x400x220x440x7F0x7E0x420x840x430x040x420x040x420x84
0x7E0x640x420x240x420x040x420x040x420x040x7E0x040x420x280x000x10
/*--??文字:??畢??--*/
0x200x800x200x880x200xB00x3E0xC00x200x800x200x840x260x840x380x7C
0x210x000x010x000xFF0xFE0x010x000x010x000x010x000x010x000x010x00
?????文件?????267616??2004-03-01?16:59??16x32LED點陣屏74hc154和595\VB\HZK16.dat
?????文件??????21847??2013-04-28?20:05??16x32LED點陣屏74hc154和595\VB\LED.frm
?????文件????????150??2013-04-28?20:05??16x32LED點陣屏74hc154和595\VB\LED.frx
?????文件?????????46??2013-04-28?20:04??16x32LED點陣屏74hc154和595\VB\LED.log
?????文件????????758??2013-04-28?20:05??16x32LED點陣屏74hc154和595\VB\LED.vbp
?????文件?????????52??2013-04-29?11:23??16x32LED點陣屏74hc154和595\VB\LED.vbw
?????文件??????65536??2011-02-23?17:36??16x32LED點陣屏74hc154和595\VB\LED點陣控制.exe
?????文件?????103744??2013-03-19?15:06??16x32LED點陣屏74hc154和595\VB\MSCOMM32.OCX
?????文件??????44846??2013-03-19?18:54??16x32LED點陣屏74hc154和595\VB\MSCOMM32_90465.rar
?????文件????????188??2011-02-23?17:35??16x32LED點陣屏74hc154和595\VB\MSSCCPRJ.SCC
?????文件????????132??2013-05-10?10:18??16x32LED點陣屏74hc154和595\仿真\dianzeng.DO
?????文件?????118308??2013-05-10?10:10??16x32LED點陣屏74hc154和595\仿真\dianzeng.DSN
?????文件??????19182??2013-05-10?10:18??16x32LED點陣屏74hc154和595\仿真\dianzeng.EDF
?????文件??????25260??2013-05-10?10:21??16x32LED點陣屏74hc154和595\仿真\dianzeng.LYT
?????文件????????768??2015-03-12?21:18??16x32LED點陣屏74hc154和595\仿真\dianzeng.PWI
?????文件???????5032??2013-05-10?10:10??16x32LED點陣屏74hc154和595\仿真\dianzeng.SDF
?????文件?????118308??2013-05-10?10:05??16x32LED點陣屏74hc154和595\仿真\Last?Loaded?dianzeng.DBK
?????文件??????14278??2013-04-28?18:41??16x32LED點陣屏74hc154和595\仿真\代碼\32x16\dian.c
?????文件??????33007??2013-04-28?19:22??16x32LED點陣屏74hc154和595\仿真\代碼\32x16\dian.LST
?????文件??????20823??2013-04-28?19:22??16x32LED點陣屏74hc154和595\仿真\代碼\32x16\dian.OBJ
?????文件??????18031??2013-04-28?19:22??16x32LED點陣屏74hc154和595\仿真\代碼\32x16\dianzhen
?????文件???????8324??2013-04-28?19:22??16x32LED點陣屏74hc154和595\仿真\代碼\32x16\dianzhen.hex
?????文件?????????45??2013-04-28?19:22??16x32LED點陣屏74hc154和595\仿真\代碼\32x16\dianzhen.lnp
?????文件??????25322??2013-04-28?19:22??16x32LED點陣屏74hc154和595\仿真\代碼\32x16\dianzhen.M51
?????文件???????1476??2013-04-29?10:30??16x32LED點陣屏74hc154和595\仿真\代碼\32x16\dianzhen.Opt
?????文件????????186??2013-04-29?10:30??16x32LED點陣屏74hc154和595\仿真\代碼\32x16\dianzhen.plg
?????文件???????2205??2013-04-28?18:48??16x32LED點陣屏74hc154和595\仿真\代碼\32x16\dianzhen.Uv2
????.......??????1470??2013-04-28?20:55??16x32LED點陣屏74hc154和595\仿真\代碼\32x16\dianzhen_Opt.Bak
????.......??????2206??2013-04-28?17:33??16x32LED點陣屏74hc154和595\仿真\代碼\32x16\dianzhen_Uv2.Bak
?????文件???????6376??2005-03-22?15:22??16x32LED點陣屏74hc154和595\仿真\代碼\32x16\STARTUP.A51
............此處省略26個文件信息
