  • 大小: 3.83MB
    文件類(lèi)型: .rar
    發(fā)布日期: 2023-09-09
  • 語(yǔ)言: VB
  • 標(biāo)簽: MP3軟解壓??
使用Helix庫(kù)軟解播放MP3,效果還可以。 MP3文件支持標(biāo)準(zhǔn)的采用率(27000這種非標(biāo)準(zhǔn)采樣率不支持),支持CBR與VBR 主芯片使用STM32F103RET,STM32F103VET,STM32F103ZET及更高RAM的芯片 SD卡僅支持FAT32文件格式(exFAT不支持) 不支持長(zhǎng)文件名,只支持8.3文件名格式,不支持中文文件名 播放的音頻文件需要放在\music目錄下
??*?@file????system_stm32f1xx.c
??*?@author??MCD?Application?Team
??*?@version?V4.1.0
??*?@date????29-April-2016
??*?@brief???CMSIS?Cortex-M3?Device?Peripheral?Access?layer?System?Source?File.
??*?1.??This?file?provides?two?functions?and?one?global?variable?to?be?called?from?
??*?????user?application:
??*??????-?SystemInit():?Setups?the?system?clock?(System?clock?source?PLL?Multiplier
??*??????????????????????factors?AHB/APBx?prescalers?and?Flash?settings).?
??*??????????????????????This?function?is?called?at?startup?just?after?reset?and?
??*??????????????????????before?branch?to?main?program.?This?call?is?made?inside
??*??????????????????????the?“startup_stm32f1xx_xx.s“?file.
??*??????-?SystemCoreClock?variable:?Contains?the?core?clock?(HCLK)?it?can?be?used
??*??????????????????????????????????by?the?user?application?to?setup?the?SysTick?
??*??????????????????????????????????timer?or?configure?other?parameters.
??*??????-?SystemCoreClockUpdate():?Updates?the?variable?SystemCoreClock?and?must
??*?????????????????????????????????be?called?whenever?the?core?clock?is?changed
??*?????????????????????????????????during?program?execution.
??*?2.?After?each?device?reset?the?HSI?(8?MHz)?is?used?as?system?clock?source.
??*????Then?SystemInit()?function?is?called?in?“startup_stm32f1xx_xx.s“?file?to
??*????configure?the?system?clock?before?to?branch?to?main?program.
??*?4.?The?default?value?of?HSE?crystal?is?set?to?8?MHz?(or?25?MHz?depending?on
??*????the?product?used)?refer?to?“HSE_VALUE“.?
??*????When?HSE?is?used?as?system?clock?source?directly?or?through?PLL?and?you
??*????are?using?different?crystal?you?have?to?adapt?the?HSE?value?to?your?own
??*????configuration.
??*?@attention
©?COPYRIGHT(c)?2016?STMicroelectronics
??*?Redistribution?and?use?in?source?and?binary?forms?with?or?without?modification
??*?are?permitted?provided?that?the?following?conditions?are?met:
??*???1.?Redistributions?of?source?code?must?retain?the?above?copyright?notice
??*??????this?list?of?conditions?and?the?following?disclaimer.
??*???2.?Redistributions?in?binary?form?must?reproduce?the?above?copyright?notice
??*??????this?list?of?conditions?and?the?following?disclaimer?in?the?documentation
??*??????and/or?other?materials?provided?with?the?distribution.
??*???3.?Neither?the?name?of?STMicroelectronics?nor?the?names?of?its?contributors
??*??????may?be?used?to?endorse?or?promote?products?derived?from?this?software
??*??????without?specific?prior?written?permission.
??*?THIS?SOFTWARE?IS?PROVIDED?BY?THE?COPYRIGHT?HOLDERS?AND?CONTRIBUTORS?“AS?IS“
??*?AND?ANY?EXPRESS?OR?IMPLIED?WARRANTIES?INCLUDING?BUT?NOT?LIMITED?TO?THE
??*?IMPLIED?WARRANTIE
?????文件?????542970??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Include\stm32f100xb.h
?????文件?????587973??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Include\stm32f100xe.h
?????文件?????492587??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Include\stm32f101x6.h
?????文件?????502788??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Include\stm32f101xb.h
?????文件?????580299??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Include\stm32f101xe.h
?????文件?????597371??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Include\stm32f101xg.h
?????文件?????585549??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Include\stm32f102x6.h
?????文件?????594987??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Include\stm32f102xb.h
?????文件?????917060??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Include\stm32f103x6.h
?????文件?????927261??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Include\stm32f103xb.h
?????文件????1013638??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Include\stm32f103xe.h
?????文件????1027719??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Include\stm32f103xg.h
?????文件????1300804??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Include\stm32f105xc.h
?????文件????1381619??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Include\stm32f107xc.h
?????文件???????8815??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Include\stm32f1xx.h
?????文件???????3335??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Include\system_stm32f1xx.h
?????文件??????15094??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Source\Templates\arm\startup_stm32f100xb.s
?????文件??????16682??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Source\Templates\arm\startup_stm32f100xe.s
?????文件??????12531??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Source\Templates\arm\startup_stm32f101x6.s
?????文件??????12904??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Source\Templates\arm\startup_stm32f101xb.s
?????文件??????15016??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Source\Templates\arm\startup_stm32f101xe.s
?????文件??????15775??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Source\Templates\arm\startup_stm32f101xg.s
?????文件??????12853??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Source\Templates\arm\startup_stm32f102x6.s
?????文件??????13238??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Source\Templates\arm\startup_stm32f102xb.s
?????文件??????13416??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Source\Templates\arm\startup_stm32f103x6.s
?????文件??????13801??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Source\Templates\arm\startup_stm32f103xb.s
?????文件??????16358??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Source\Templates\arm\startup_stm32f103xe.s
?????文件??????16812??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Source\Templates\arm\startup_stm32f103xg.s
?????文件??????16620??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Source\Templates\arm\startup_stm32f105xc.s
?????文件??????16800??2016-07-19?09:58??SD播放MP3\Drivers\CMSIS\Device\ST\STM32F1xx\Source\Templates\arm\startup_stm32f107xc.s
............此處省略577個(gè)文件信息
