  • 大小: 1.7MB
    發布日期: 2023-08-31
  • 標簽: Demo??讀卡器??API??
明華讀卡器(API+Demo+手冊)包含Delphi+Pb+VB+VC+Vfp源碼
//?ReadWriteTest.cpp?:?Defines?the?class?behaviors?for?the?application.
#include?“stdafx.h“
#include?“ReadWriteTest.h“
#include?“ReadWriteTestDlg.h“
#ifdef?_DEBUG
#define?new?DEBUG_NEW
#undef?THIS_FILE
static?char?THIS_FILE[]?=?__FILE__;
//?CReadWriteTestApp
BEGIN_MESSAGE_MAP(CReadWriteTestApp?CWinApp)
//{{AFX_MSG_MAP(CReadWriteTestApp)
//?NOTE?-?the?ClassWizard?will?add?and?remove?mapping?macros?here.
//????DO?NOT?EDIT?what?you?see?in?these?blocks?of?generated?code!
//}}AFX_MSG
ON_COMMAND(ID_HELP?CWinApp::onhelp)
END_MESSAGE_MAP()
//?CReadWriteTestApp?construction
CReadWriteTestApp::CReadWriteTestApp()
//?TODO:?add?construction?code?here
//?Place?all?significant?initialization?in?InitInstance
//?The?one?and?only?CReadWriteTestApp?object
CReadWriteTestApp?theApp;
//?CReadWriteTestApp?initialization
BOOL?CReadWriteTestApp::InitInstance()
AfxEnableControlContainer();
//?Standard?initialization
//?If?you?are?not?using?these?features?and?wish?to?reduce?the?size
//??of?your?final?executable?you?should?remove?from?the?following
//??the?specific?initialization?routines?you?do?not?need.
#ifdef?_AFXDLL
Enable3dControls(); //?Call?this?when?using?MFC?in?a?shared?DLL
#else
Enable3dControlsStatic(); //?Call?this?when?linking?to?MFC?statically
CReadWriteTestDlg?dlg;
m_pMainWnd?=?&dlg;
int?nResponse?=?dlg.DoModal();
if?(nResponse?==?IDOK)
//?TODO:?Place?code?here?to?handle?when?the?dialog?is
//??dismissed?with?OK
else?if?(nResponse?==?IDCANCEL)
//??dismissed?with?Cancel
//?Since?the?dialog?has?been?closed?return?FALSE?so?that?we?exit?the
//??application?rather?than?start?the?application‘s?message?pump.
return?FALSE;
?????文件?????114688??2013-08-20?19:59??明華讀卡器\API\mwrf32.dll
?????文件??????18762??2013-08-20?19:59??明華讀卡器\API\mwrf32.h
?????文件??????38794??2013-08-20?19:59??明華讀卡器\API\mwrf32.lib
?????文件?????487424??2013-08-20?19:58??明華讀卡器\Demo\DemoHRF2.0.exe
?????文件?????311296??2013-08-20?19:59??明華讀卡器\Demo\HRFFUDANDemo1.0.exe
?????文件?????311296??2013-08-20?19:59??明華讀卡器\Demo\HRFSHC1102Demo1.0.exe
?????文件?????????47??2015-01-04?15:15??明華讀卡器\Demo\mf30.ini
?????文件?????114688??2013-08-20?19:59??明華讀卡器\Demo\mwrf32.dll
?????文件?????133205??2013-08-20?19:59??明華讀卡器\Demo\mwrfhelp.chm
?????文件?????114688??2013-08-20?19:59??明華讀卡器\Examples\Delphi5\mwrf32.dll
?????文件????????386??2013-08-20?19:58??明華讀卡器\Examples\Delphi5\Rfexamd.cfg
?????文件???????1043??2013-08-20?19:58??明華讀卡器\Examples\Delphi5\Rfexamd.dof
?????文件????????191??2013-08-20?19:58??明華讀卡器\Examples\Delphi5\Rfexamd.dpr
?????文件?????399360??2015-01-26?09:00??明華讀卡器\Examples\Delphi5\Rfexamd.exe
?????文件????????876??2013-08-20?19:58??明華讀卡器\Examples\Delphi5\Rfexamd.res
?????文件???????1243??2013-08-20?19:58??明華讀卡器\Examples\Delphi5\rfexamp.dfm
?????文件??????19873??2015-01-26?08:56??明華讀卡器\Examples\Delphi5\rfexamp.pas
?????文件??????93184??2013-08-20?19:58??明華讀卡器\Examples\Pb5\sample.pbl
?????文件???????6439??2013-08-20?19:58??明華讀卡器\Examples\VB5.0\example.bas
?????文件??????24241??2013-08-20?19:58??明華讀卡器\Examples\VB5.0\sample.frm
?????文件?????????56??2013-08-20?19:58??明華讀卡器\Examples\VB5.0\sample.frx
?????文件????????694??2013-08-20?19:58??明華讀卡器\Examples\VB5.0\sample.vbp
?????文件?????????79??2013-08-20?19:58??明華讀卡器\Examples\VB5.0\sample.vbw
?????文件???????3705??2013-08-20?19:58??明華讀卡器\Examples\VC6.0\ReadMe.txt
?????文件??????22824??2013-08-20?19:58??明華讀卡器\Examples\VC6.0\ReadWriteTest.aps
?????文件???????2089??2013-08-20?19:58??明華讀卡器\Examples\VC6.0\ReadWriteTest.clw
?????文件???????2161??2013-08-20?19:58??明華讀卡器\Examples\VC6.0\ReadWriteTest.cpp
?????文件???????4409??2013-08-20?19:58??明華讀卡器\Examples\VC6.0\ReadWriteTest.dsp
?????文件????????549??2013-08-20?19:58??明華讀卡器\Examples\VC6.0\ReadWriteTest.dsw
?????文件???????1401??2013-08-20?19:58??明華讀卡器\Examples\VC6.0\ReadWriteTest.h
............此處省略32個文件信息
