  • 大小: 1.13MB
    發布日期: 2023-08-16
個人畢業設計,實現用51單片機控制點陣顯示漢字,并可以通過VB編寫的上位機來改變漢字及顯示漢字的移動方向和移動速度。
//32*16點陣屏//
//作者:譚錦標
//日期:2010-12-28
//晶振:11.059MHZ
//包含頭文件
sbit?SCK?=?P1^4;
sbit?AB?=?P1^3;
sbit?st?=?P1^2;
sbit?sh?=?P1^1;
sbit?dat?=?P1^0;
//宏定義
typedef?unsigned?char?uchar;
typedef?unsigned?int?uint;
//全局變量
uint?speed?=?20; //滾動速度控制
uchar?DisplayMode?=?0;? //顯示模式選擇
uint?count?=?0;
uchar?ctrl?=?0;
//顯示內容
uchar?display[15][32]={
0x000x000x000x000x000x000x000x000x000x000x000x000x000x000x000x00
/*--??文字:??0??--*/
0x000x000x000x000x000x000x070xF00x1C0x380x380x1C0x380x1C0x780x1E
0x780x1E0x380x1C0x380x1C0x380x1C0x1C0x380x070xE00x000x000x000x00
/*--??文字:??7??--*/
0x000x000x000x000x000x000x1F0xFE0x380x0C0x300x100x000x300x000x60
0x000xC00x010x800x030x800x030x800x030x800x030x800x000x000x000x00
/*--??文字:??計??--*/
/*--??宋體12;??此字體下對應的點陣為:寬x高=16x16???--*/
0x000x400x200x400x100x400x100x400x000x400x000x400xF70xFE0x100x40
0x100x400x100x400x100x400x100x400x140x400x180x400x100x400x000x40
/*--??文字:??嵌??--*/
0x010x000x210x080x210x080x3F0xF80x220x280x220x200xFF0x7C0x220x44
0x220xA80x220x200x3E0x200x220x200x220x500x220x480x3E0x8E0x210x04
/*--??文字:??譚??--*/
0x400x040x2F0xFE0x200xA00x070xFC0x040xA40xE70xFC0x200x080x230xFC
0x220x080x230xF80x220x080x230xF80x280x400x370xFE0x200x400x000x40
/*--??文字:??錦??--*/
0x200x400x200x880x3B0xFC0x420x080x830xF80x7A0x080x230xF80x200x40
0xFF0xFC0x240x440x240x440x240x440x2C0x540x300x480x200x400x000x40
/*--??文字:??標??--*/
0x100x000x100x100x130xF80x100x000xFC0x000x100x040x370xFE0x380x40
0x540x400x510x500x910x480x120x4C0x140x440x100x400x110x400x100x80
/*--??文字:??畢??--*/
0x200x800x200x880x200xB00x3E0xC00x200x800x200x840x260x840x380x7C
0x210x000x010x000xFF0xFE0x010x000x010x000x010x000x010x000x010x00
/*--??文字:??業??--*/
0x040x400x040x400x040x400x040x400x440x440x24
?????文件??????33792??2011-01-11?14:08??基于51單片機帶上位機控制點陣顯示漢字\C51\Debug\vc60.idb
?????文件??????28672??2011-01-11?14:08??基于51單片機帶上位機控制點陣顯示漢字\C51\Debug\vc60.pdb
?????文件??????10750??2011-02-27?15:50??基于51單片機帶上位機控制點陣顯示漢字\C51\dian.c
?????文件??????22048??2011-01-14?14:38??基于51單片機帶上位機控制點陣顯示漢字\C51\dian.LST
?????文件??????15412??2011-01-14?14:38??基于51單片機帶上位機控制點陣顯示漢字\C51\dian.OBJ
?????文件???????7627??2011-01-12?22:25??基于51單片機帶上位機控制點陣顯示漢字\C51\dianzhen.hex
?????文件?????????29??2011-01-12?22:25??基于51單片機帶上位機控制點陣顯示漢字\C51\dianzhen.lnp
?????文件??????16949??2011-01-12?22:25??基于51單片機帶上位機控制點陣顯示漢字\C51\dianzhen.M51
?????文件????????986??2011-02-10?20:35??基于51單片機帶上位機控制點陣顯示漢字\C51\dianzhen.Opt
?????文件??????????0??2011-02-10?20:34??基于51單片機帶上位機控制點陣顯示漢字\C51\dianzhen.plg
?????文件???????1681??2011-01-14?14:46??基于51單片機帶上位機控制點陣顯示漢字\C51\dianzhen.Uv2
?????文件????????986??2011-02-02?23:42??基于51單片機帶上位機控制點陣顯示漢字\C51\dianzhen_Opt.Bak
?????文件???????1681??2011-01-12?17:27??基于51單片機帶上位機控制點陣顯示漢字\C51\dianzhen_Uv2.Bak
?????文件?????267616??2004-03-01?16:59??基于51單片機帶上位機控制點陣顯示漢字\VB\HZK16.dat
?????文件??????22158??2011-02-24?16:38??基于51單片機帶上位機控制點陣顯示漢字\VB\LED.frm
?????文件????????150??2011-02-24?16:38??基于51單片機帶上位機控制點陣顯示漢字\VB\LED.frx
?????文件?????????98??2011-02-23?17:34??基于51單片機帶上位機控制點陣顯示漢字\VB\LED.log
?????文件????????770??2011-02-24?16:38??基于51單片機帶上位機控制點陣顯示漢字\VB\LED.vbp
?????文件?????????52??2011-02-24?16:38??基于51單片機帶上位機控制點陣顯示漢字\VB\LED.vbw
?????文件??????65536??2011-02-23?17:36??基于51單片機帶上位機控制點陣顯示漢字\VB\LED點陣控制.exe
?????文件????????188??2011-02-23?17:35??基于51單片機帶上位機控制點陣顯示漢字\VB\MSSCCPRJ.SCC
?????文件?????????94??2012-04-22?19:35??基于51單片機帶上位機控制點陣顯示漢字\使用必看.txt
?????文件??????42256??2010-06-01?23:03??基于51單片機帶上位機控制點陣顯示漢字\原理圖\原理圖.pdf
?????文件??????51974??2008-07-04?20:00??基于51單片機帶上位機控制點陣顯示漢字\芯片資料\74HC164.pdf
?????文件?????125142??2008-07-11?14:18??基于51單片機帶上位機控制點陣顯示漢字\芯片資料\74HC595.pdf
?????文件??????35328??2011-02-27?16:46??基于51單片機帶上位機控制點陣顯示漢字\論文及各種材料\20070861133--譚錦標--中期檢查表.doc
?????文件??????58880??2011-02-27?15:39??基于51單片機帶上位機控制點陣顯示漢字\論文及各種材料\20070861133--譚錦標--開題報告.doc
?????文件??????31744??2011-02-27?16:02??基于51單片機帶上位機控制點陣顯示漢字\論文及各種材料\20070861133--譚錦標--文獻綜述.doc
............此處省略15個文件信息
