  • 大小: 3.64MB
    發布日期: 2023-08-13
  • 標簽: 組態王??SDK??VC++??
組態王SDK開發包, 含VC, VB例程
//?AddItemDlg.cpp?:?implementation?file
#include?“stdafx.h“
#include?“vckingclient.h“
#include?“AddItemDlg.h“
#include?“mainFrm.h“
#include?“vckingclientDoc.h“
#include?“vckingclientView.h“
#ifdef?_DEBUG
#define?new?DEBUG_NEW
#undef?THIS_FILE
static?char?THIS_FILE[]?=?__FILE__;
//?CAddItemDlg?dialog
CAddItemDlg::CAddItemDlg(CWnd*?pParent?/*=NULL*/)
:?CDialog(CAddItemDlg::IDD?pParent)
//{{AFX_DATA_INIT(CAddItemDlg)
m_Path?=?_T(““);
m_Name?=?_T(““);
m_value?=?_T(““);
//}}AFX_DATA_INIT
void?CAddItemDlg::DoDataExchange(CDataExchange*?pDX)
CDialog::DoDataExchange(pDX);
//{{AFX_DATA_MAP(CAddItemDlg)
DDX_Control(pDX?IDC_TREE1?m_ItemName);
DDX_Text(pDX?IDC_EDIT1?m_Path);
DDX_Text(pDX?IDC_EDIT2?m_Name);
DDX_Text(pDX?IDC_EDIT3?m_value);
//}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(CAddItemDlg?CDialog)
//{{AFX_MSG_MAP(CAddItemDlg)
ON_BN_CLICKED(IDC_BUTTON1?OnButton1)
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
//?CAddItemDlg?message?handlers
void?CAddItemDlg::OnButton1()?
//?TODO:?Add?your?control?notification?handler?code?here
HTREEITEM?temp?=?m_ItemName.GetSelectedItem();
if?(temp?==?NULL)
return;
m_Name?=?m_ItemName.GetItemText(temp);
CMainframe*?main?=?(CMainframe*)AfxGetMainWnd();
CVckingclientView*?view?=?(CVckingclientView*)main->GetActiveView(?)?;
view->m_colName?=?m_Name;
view->ViewAddTag();
UpdateData(FALSE);
BOOL?CAddItemDlg::OnInitDialog()?
CDialog::OnInitDialog();
CObArray*?temp?=?&(view->m_ItemList?);
int?count?=?temp->GetSize();
for?(int?i?=?0;i {
ItemSin*?Item?=?(ItemSin*)temp->GetAt(i);
m_ItemName.InsertItem(?Item->ItemName?TVI_ROOTTVI_LAST?);
//?TODO:?Add?extra?initialization?here
return?TRUE;??//?return?TRUE?unless?you?set?the?focus?to?a?control
??????????????//?EXCEPTION:?OCX?Property?Pages?should?return?FALSE
void?CAddItemDlg::OnOK()?
//?TODO:?Add?extra?validation?here
CDialog::OnOK();
void?CAddItemDlg::OnCancel()?
//?TODO:?Add?extra?cleanup?here
CDialog::OnCancel();
?????文件???????1139??2001-09-18?14:01??SDK\Readme.txt
?????文件???????2401??2001-09-19?14:16??SDK\SDK-VC例程\AddItemDlg.cpp
?????文件???????1333??2001-09-19?14:12??SDK\SDK-VC例程\AddItemDlg.h
?????文件??????18547??2001-09-19?14:16??SDK\SDK-VC例程\Debug\AddItemDlg.obj
?????文件??????57412??2001-09-18?11:16??SDK\SDK-VC例程\Debug\kingvewcliend.dll
?????文件???????4412??2001-09-07?15:46??SDK\SDK-VC例程\Debug\kingvewcliend.lib
?????文件??????19959??2001-09-18?14:03??SDK\SDK-VC例程\Debug\MainFrm.obj
?????文件?????105664??2001-09-18?14:03??SDK\SDK-VC例程\Debug\StdAfx.obj
?????文件?????222208??2001-09-19?16:35??SDK\SDK-VC例程\Debug\VC60.IDB
?????文件?????372736??2001-09-19?14:27??SDK\SDK-VC例程\Debug\VC60.PDB
?????文件?????122944??2001-09-19?14:27??SDK\SDK-VC例程\Debug\vckingclient.exe
?????文件?????342880??2001-09-19?14:27??SDK\SDK-VC例程\Debug\vckingclient.ilk
?????文件??????23464??2001-09-19?14:16??SDK\SDK-VC例程\Debug\vckingclient.obj
?????文件????5502092??2001-09-18?14:03??SDK\SDK-VC例程\Debug\vckingclient.pch
?????文件?????533504??2001-09-19?14:27??SDK\SDK-VC例程\Debug\vckingclient.pdb
?????文件???????7532??2001-09-19?13:36??SDK\SDK-VC例程\Debug\vckingclient.res
?????文件??????15053??2001-09-18?14:03??SDK\SDK-VC例程\Debug\vckingclientDoc.obj
?????文件??????34802??2001-09-19?14:27??SDK\SDK-VC例程\Debug\vckingclientView.obj
?????文件???????1914??2001-09-18?10:15??SDK\SDK-VC例程\kingopccli.h
?????文件??????57412??2001-09-18?11:16??SDK\SDK-VC例程\kingvewcliend.dll
?????文件???????4412??2001-09-18?10:45??SDK\SDK-VC例程\kingvewcliend.lib
?????文件???????2375??2001-09-18?11:36??SDK\SDK-VC例程\MainFrm.cpp
?????文件???????1440??2001-09-18?11:28??SDK\SDK-VC例程\MainFrm.h
?????文件???????4455??2001-09-18?09:29??SDK\SDK-VC例程\ReadMe.txt
?????文件??????14073??2001-09-19?16:36??SDK\SDK-VC例程\Release\AddItemDlg.obj
?????文件??????12768??2001-09-19?16:36??SDK\SDK-VC例程\Release\MainFrm.obj
?????文件????????750??2001-09-19?16:36??SDK\SDK-VC例程\Release\StdAfx.obj
?????文件??????58368??2001-09-19?16:36??SDK\SDK-VC例程\Release\VC60.IDB
?????文件??????36864??2001-09-19?16:36??SDK\SDK-VC例程\Release\vckingclient.exe
?????文件??????16234??2001-09-19?16:36??SDK\SDK-VC例程\Release\vckingclient.obj
............此處省略45個文件信息
