擁有強大的水晶報表源代碼,VB/VC和.net的示例源碼都在其中
//?CreateBasicReport.cpp?:?Defines?the?class?behaviors?for?the?application.
#include?“stdafx.h“
#include?“CreateBasicReport.h“
#include?“CreateBasicReportDlg.h“
#ifdef?_DEBUG
#define?new?DEBUG_NEW
#undef?THIS_FILE
static?char?THIS_FILE[]?=?__FILE__;
//?CCreateBasicReportApp
BEGIN_MESSAGE_MAP(CCreateBasicReportApp?CWinApp)
//{{AFX_MSG_MAP(CCreateBasicReportApp)
//?NOTE?-?the?ClassWizard?will?add?and?remove?mapping?macros?here.
//????DO?NOT?EDIT?what?you?see?in?these?blocks?of?generated?code!
//}}AFX_MSG
ON_COMMAND(ID_HELP?CWinApp::onhelp)
END_MESSAGE_MAP()
//?CCreateBasicReportApp?construction
CCreateBasicReportApp::CCreateBasicReportApp()
//?TODO:?add?construction?code?here
//?Place?all?significant?initialization?in?InitInstance
//?The?one?and?only?CCreateBasicReportApp?object
CCreateBasicReportApp?theApp;
//?CCreateBasicReportApp?initialization
BOOL?CCreateBasicReportApp::InitInstance()
AfxEnableControlContainer();
//?Standard?initialization
//?If?you?are?not?using?these?features?and?wish?to?reduce?the?size
//??of?your?final?executable?you?should?remove?from?the?following
//??the?specific?initialization?routines?you?do?not?need.
#ifdef?_AFXDLL
Enable3dControls(); //?Call?this?when?using?MFC?in?a?shared?DLL
#else
Enable3dControlsStatic(); //?Call?this?when?linking?to?MFC?statically
CCreateBasicReportDlg?dlg;
m_pMainWnd?=?&dlg;
int?nResponse?=?dlg.DoModal();
if?(nResponse?==?IDOK)
//?TODO:?Place?code?here?to?handle?when?the?dialog?is
//??dismissed?with?OK
else?if?(nResponse?==?IDCANCEL)
//??dismissed?with?Cancel
//?Since?the?dialog?has?been?closed?return?FALSE?so?that?we?exit?the
//??application?rather?than?start?the?application‘s?message?pump.
return?FALSE;
?????文件?????204800??2003-10-22?19:43??Crystal?Reports8.5部分\databa
?????文件?????110592??2003-10-22?19:43??Crystal?Reports8.5部分\databa
?????文件?????110592??2003-10-22?19:44??Crystal?Reports8.5部分\databa
?????文件???????7137??2002-08-14?17:10??Crystal?Reports8.5部分\Visual?Basic部分\ch11\Report?ob
?????文件???????4590??2001-02-03?15:06??Crystal?Reports8.5部分\Visual?Basic部分\ch11\Report?ob
?????文件????????193??2002-08-14?17:10??Crystal?Reports8.5部分\Visual?Basic部分\ch11\Report?ob
?????文件???????1367??2002-08-29?16:06??Crystal?Reports8.5部分\Visual?Basic部分\ch11\Report?ob
?????文件?????????51??2002-08-29?16:06??Crystal?Reports8.5部分\Visual?Basic部分\ch11\Report?ob
?????文件??????80719??2002-08-13?03:10??Crystal?Reports8.5部分\Visual?Basic部分\ch2\SampleReport\CrystalReport1.DCA
?????文件????????609??2002-08-13?03:10??Crystal?Reports8.5部分\Visual?Basic部分\ch2\SampleReport\CrystalReport1.Dsr
?????文件??????33304??2002-08-13?03:10??Crystal?Reports8.5部分\Visual?Basic部分\ch2\SampleReport\CrystalReport1.dsx
?????文件????????484??2002-08-13?03:10??Crystal?Reports8.5部分\Visual?Basic部分\ch2\SampleReport\Form1.frm
?????文件???????2298??2002-08-13?03:10??Crystal?Reports8.5部分\Visual?Basic部分\ch2\SampleReport\Form2.frm
?????文件????????193??2002-08-13?03:10??Crystal?Reports8.5部分\Visual?Basic部分\ch2\SampleReport\MSSCCPRJ.SCC
?????文件???????1317??2002-08-29?15:32??Crystal?Reports8.5部分\Visual?Basic部分\ch2\SampleReport\Project1.vbp
?????文件????????151??2002-08-29?15:32??Crystal?Reports8.5部分\Visual?Basic部分\ch2\SampleReport\Project1.vbw
?????文件???????5691??2002-08-13?11:38??Crystal?Reports8.5部分\Visual?Basic部分\ch3\em
?????文件????????152??2002-08-13?11:38??Crystal?Reports8.5部分\Visual?Basic部分\ch3\em
?????文件????????193??2002-08-13?11:37??Crystal?Reports8.5部分\Visual?Basic部分\ch3\em
?????文件???????1076??2002-08-29?15:36??Crystal?Reports8.5部分\Visual?Basic部分\ch3\em
?????文件?????????52??2002-08-29?15:36??Crystal?Reports8.5部分\Visual?Basic部分\ch3\em
?????文件?????599726??2002-08-13?15:32??Crystal?Reports8.5部分\Visual?Basic部分\ch4\Viewer\CrystalReport1.DCA
?????文件????????414??2002-08-13?15:32??Crystal?Reports8.5部分\Visual?Basic部分\ch4\Viewer\CrystalReport1.Dsr
?????文件?????301080??2002-08-13?15:32??Crystal?Reports8.5部分\Visual?Basic部分\ch4\Viewer\CrystalReport1.dsx
?????文件????????484??2002-08-13?13:50??Crystal?Reports8.5部分\Visual?Basic部分\ch4\Viewer\Form1.frm
?????文件??????17448??2002-08-13?16:29??Crystal?Reports8.5部分\Visual?Basic部分\ch4\Viewer\Form2.frm
?????文件???????1078??2001-02-03?15:06??Crystal?Reports8.5部分\Visual?Basic部分\ch4\Viewer\Icons\ARW03LT.ICO
?????文件???????1078??2001-02-03?15:06??Crystal?Reports8.5部分\Visual?Basic部分\ch4\Viewer\Icons\ARW03RT.ICO
?????文件???????1078??2001-02-03?15:06??Crystal?Reports8.5部分\Visual?Basic部分\ch4\Viewer\Icons\ARW04LT.ICO
?????文件???????1078??2001-02-03?15:06??Crystal?Reports8.5部分\Visual?Basic部分\ch4\Viewer\Icons\ARW04RT.ICO
............此處省略499個文件信息
