  • 大小: 19.14MB
    發布日期: 2023-07-08
  • 標簽: ADT-8840??
以太網4軸運動控制器開發包,內含vb,vc,wince系統開發包和源碼例程,含控制器驅動,開發包,函數功能說明書。
//?evc8840.cpp?:?Defines?the?class?behaviors?for?the?application.
#include?“stdafx.h“
#include?“evc8840.h“
#include?“evc8840Dlg.h“
#ifdef?_DEBUG
#define?new?DEBUG_NEW
#undef?THIS_FILE
static?char?THIS_FILE[]?=?__FILE__;
//?CEvc8840App
BEGIN_MESSAGE_MAP(CEvc8840App?CWinApp)
//{{AFX_MSG_MAP(CEvc8840App)
//?NOTE?-?the?ClassWizard?will?add?and?remove?mapping?macros?here.
//????DO?NOT?EDIT?what?you?see?in?these?blocks?of?generated?code!
//}}AFX_MSG
END_MESSAGE_MAP()
//?CEvc8840App?construction
CEvc8840App::CEvc8840App()
:?CWinApp()
//?TODO:?add?construction?code?here
//?Place?all?significant?initialization?in?InitInstance
//?The?one?and?only?CEvc8840App?object
CEvc8840App?theApp;
//?CEvc8840App?initialization
BOOL?CEvc8840App::InitInstance()
if?(!AfxSocketInit())
AfxMessageBox(IDP_SOCKETS_INIT_FAILED);
return?FALSE;
//?Standard?initialization
//?If?you?are?not?using?these?features?and?wish?to?reduce?the?size
//??of?your?final?executable?you?should?remove?from?the?following
//??the?specific?initialization?routines?you?do?not?need.
CEvc8840Dlg?dlg;
m_pMainWnd?=?&dlg;
int?nResponse?=?dlg.DoModal();
if?(nResponse?==?IDOK)
//?TODO:?Place?code?here?to?handle?when?the?dialog?is
//??dismissed?with?OK
else?if?(nResponse?==?IDCANCEL)
//??dismissed?with?Cancel
//?Since?the?dialog?has?been?closed?return?FALSE?so?that?we?exit?the
//??application?rather?than?start?the?application‘s?message?pump.
return?FALSE;
?????文件?????????45??2009-12-10?16:39??ADT-8840\0.驅動\說明.txt
?????文件????????102??2009-07-31?16:55??ADT-8840\1.開發包\0.開發包\README.TXT
?????文件??????32015??2010-07-27?11:24??ADT-8840\1.開發包\0.開發包\VB\Adt8840.bas
?????文件?????151552??2010-04-09?10:42??ADT-8840\1.開發包\0.開發包\VB\adt8840.dll
?????文件????????741??2009-08-24?09:22??ADT-8840\1.開發包\0.開發包\VB\動態庫調用方法.txt
?????文件?????151552??2010-04-09?10:42??ADT-8840\1.開發包\0.開發包\VC\adt8840.dll
?????文件??????39534??2010-07-28?08:50??ADT-8840\1.開發包\0.開發包\VC\adt8840.h
?????文件??????32362??2010-04-09?10:42??ADT-8840\1.開發包\0.開發包\VC\adt8840.lib
?????文件???????1640??2009-07-31?17:04??ADT-8840\1.開發包\0.開發包\VC\README.txt
?????文件??????47104??2010-04-14?09:52??ADT-8840\1.開發包\0.開發包\WIN?CE\evc8840lib.dll
?????文件??????41379??2010-04-13?11:55??ADT-8840\1.開發包\0.開發包\WIN?CE\evc8840lib.h
?????文件??????32498??2010-04-14?09:52??ADT-8840\1.開發包\0.開發包\WIN?CE\evc8840lib.lib
?????文件???????1234??2010-02-22?17:04??ADT-8840\1.開發包\0.開發包\WIN?CE\README.txt
?????文件?????166354??2010-07-28?09:49??ADT-8840\1.開發包\0.開發包.rar
?????文件????????373??2009-10-24?18:30??ADT-8840\1.開發包\1.示范程序\README.TXT
?????文件??????83048??2010-07-28?09:18??ADT-8840\1.開發包\1.示范程序\WINCE\evc8840\evc8840.aps
?????文件???????1940??2010-02-22?16:56??ADT-8840\1.開發包\1.示范程序\WINCE\evc8840\evc8840.cpp
?????文件??????44032??2010-04-14?13:33??ADT-8840\1.開發包\1.示范程序\WINCE\evc8840\evc8840.exe
?????文件???????1531??2010-02-04?10:15??ADT-8840\1.開發包\1.示范程序\WINCE\evc8840\evc8840.h
?????文件??????27238??2010-04-13?17:42??ADT-8840\1.開發包\1.示范程序\WINCE\evc8840\evc8840.rc
?????文件?????156672??2010-07-28?09:20??ADT-8840\1.開發包\1.示范程序\WINCE\evc8840\evc8840.vcb
?????文件??????10684??2010-07-28?09:18??ADT-8840\1.開發包\1.示范程序\WINCE\evc8840\evc8840.vcc
?????文件???????2364??2010-07-28?09:18??ADT-8840\1.開發包\1.示范程序\WINCE\evc8840\evc8840.vcl
?????文件??????53760??2010-07-28?09:20??ADT-8840\1.開發包\1.示范程序\WINCE\evc8840\evc8840.vco
?????文件???????7330??2010-02-22?16:58??ADT-8840\1.開發包\1.示范程序\WINCE\evc8840\evc8840.vcp
?????文件????????544??2010-02-04?11:23??ADT-8840\1.開發包\1.示范程序\WINCE\evc8840\evc8840.vcw
?????文件??????34458??2010-04-14?13:33??ADT-8840\1.開發包\1.示范程序\WINCE\evc8840\evc8840Dlg.cpp
?????文件???????4141??2010-04-13?17:30??ADT-8840\1.開發包\1.示范程序\WINCE\evc8840\evc8840Dlg.h
?????文件??????47104??2010-04-14?09:52??ADT-8840\1.開發包\1.示范程序\WINCE\evc8840\evc8840lib.dll
?????文件??????41379??2010-04-13?11:55??ADT-8840\1.開發包\1.示范程序\WINCE\evc8840\evc8840lib.h
............此處省略192個文件信息
