  • 大小: 463KB
    發布日期: 2023-02-06
  • 標簽: 監控系統??
監控系統源代碼,針對串口通信方面的一個比較完整的軟件,有獨立的數據聯網協議.
using?System;
using?System.Data;
using?System.Configuration;
using?System.Collections;
using?System.Web;
using?System.Web.Security;
using?System.Web.UI;
using?System.Web.UI.WebControls;
using?System.Web.UI.WebControls.WebParts;
using?System.Web.UI.HtmlControls;
//51-aspx
public?partial?class?_Default?:?System.Web.UI.Page
????BookManage?bookmanage?=?new?BookManage();
????ReaderManage?readermanage?=?new?ReaderManage();
????protected?void?Page_Load(object?sender?EventArgs?e)
????????this.title?=?“圖書館管理系統主頁“;
????????DataSet?bookds?=?bookmanage.GetBookSort(“tb_bookinfo“);
????????gvBookSort.DataSource?=?bookds;
????????gvBookSort.DataBind();
????????DataSet?readerds?=?readermanage.GetReaderSort(“tb_reader“);
????????gvReaderSort.DataSource?=?readerds;
????????gvReaderSort.DataBind();
????protected?void?gvBookSort_RowDataBound(object?sender?GridViewRowEventArgs?e)
????????if?(e.Row.RowIndex?!=?-1)
????????????int?id?=?e.Row.RowIndex?+?1;
????????????e.Row.Cells[0].Text?=?id.ToString();
????protected?void?gvReaderSort_RowDataBound(object?sender?GridViewRowEventArgs?e)
????????gvBookSort_RowDataBound(sender?e);
?????文件???????4775??2006-11-03?20:33??LibraryMS\App_Code\AdminManage.cs
?????文件???????4458??2006-11-03?20:33??LibraryMS\App_Code\BookcaseManage.cs
?????文件??????11518??2006-11-03?20:33??LibraryMS\App_Code\BookManage.cs
?????文件??????11109??2006-11-03?20:33??LibraryMS\App_Code\BorrowandBackManage.cs
?????文件???????3747??2006-11-03?20:33??LibraryMS\App_Code\BTypeManage.cs
?????文件???????7223??2006-11-03?20:33??LibraryMS\App_Code\Database.cs
?????文件???????5085??2006-11-03?20:33??LibraryMS\App_Code\LibraryManage.cs
?????文件???????1434??2006-11-03?20:33??LibraryMS\App_Code\OperatorClass.cs
?????文件???????3886??2006-11-03?20:33??LibraryMS\App_Code\PubManage.cs
?????文件???????5462??2006-11-03?20:33??LibraryMS\App_Code\PurviewManage.cs
?????文件??????11352??2006-11-03?20:33??LibraryMS\App_Code\ReaderManage.cs
?????文件???????3688??2006-11-03?20:33??LibraryMS\App_Code\RTypeManage.cs
?????文件???????2059??2006-11-03?20:33??LibraryMS\App_Code\ValidateClass.cs
?????文件???????8131??2006-11-03?20:33??LibraryMS\BookBRManage\BorrowBook.aspx
?????文件???????5416??2006-11-03?20:33??LibraryMS\BookBRManage\BorrowBook.aspx.cs
?????文件???????6142??2006-11-03?20:33??LibraryMS\BookBRManage\ReturnBook.aspx
?????文件???????3874??2006-11-03?20:33??LibraryMS\BookBRManage\ReturnBook.aspx.cs
?????文件???????6841??2006-11-03?20:33??LibraryMS\BookManage\AddBook.aspx
?????文件???????6508??2006-11-03?20:33??LibraryMS\BookManage\AddBook.aspx.cs
?????文件???????3004??2006-11-03?20:33??LibraryMS\BookManage\AddBType.aspx
?????文件???????1697??2006-11-03?20:33??LibraryMS\BookManage\AddBType.aspx.cs
?????文件???????3622??2006-11-03?20:33??LibraryMS\BookManage\BookManage.aspx
?????文件???????1292??2006-11-03?20:33??LibraryMS\BookManage\BookManage.aspx.cs
?????文件???????3045??2006-11-03?20:33??LibraryMS\BookManage\BTypeManage.aspx
?????文件???????2168??2006-11-03?20:33??LibraryMS\BookManage\BTypeManage.aspx.cs
?????文件???????4256??2006-11-03?20:33??LibraryMS\Common\ChanagePwd.aspx
?????文件???????1351??2006-11-03?20:33??LibraryMS\Common\ChanagePwd.aspx.cs
?????文件????????447??2006-11-03?20:33??LibraryMS\Common\checkcode.aspx
?????文件???????3163??2006-11-03?20:33??LibraryMS\Common\checkcode.aspx.cs
?????文件????????673??2008-12-01?10:13??LibraryMS\css.css
............此處省略90個文件信息
