DWGdirect 3.3.0+DWGdirectXVB.chm 免費(fèi) DWGdirect控件,有vb6.0和 .net 的使用幫助,
//?Copyright??2009-2010?Open?Design?Alliance?(the?“Alliance“)?
//?This?software?is?owned?by?the?Alliance?and?may?only?be?incorporated?into?
//?application?programs?owned?by?members?of?the?Alliance?subject?to?a?signed?
//?Membership?Agreement?and?Supplemental?Software?License?Agreement?with?the
//?Alliance.?The?structure?and?organization?of?this?software?are?the?valuable?
//?trade?secrets?of?the?Alliance?and?its?suppliers.?The?software?is?also?
//?protected?by?copyright?law?and?international?treaty?provisions.?Application?
//?programs?incorporating?this?software?must?include?the?following?statement?
//?with?their?copyright?notices:
//?Teigha?NET?for?.dwg?files?2009-2010?by?Open?Design?Alliance.?All?rights?reserved.
//?By?use?of?this?software?you?acknowledge?and?accept?these?terms.
//?*DWG?is?the?native?and?proprietary?file?format?for?AutoCAD?and?a?trademark?
//?of?Autodesk?Inc.?The?Open?Design?Alliance?is?not?associated?with?Autodesk.
using?System;
using?System.Collections.Generic;
using?System.Text;
using?System.IO;
using?Teigha.DatabaseServices;
using?Teigha.Geometry;
using?Teigha.GraphicsInterface;
using?Teigha.Colors;
using?Teigha;
//?note?that?Getobject?doesn‘t?work?in?Acad?2009?so?we?use?“obsolete“?Open?instead
#pragma?warning?disable?618
namespace?OdReadExMgd
??class?DbDumper
????public?DbDumper()?{?}
????static?string?toDegreeString(double?val)
??????return?(val?*?180.0?/?Math.PI)?+?“d“;
????static?string?toHexString(int?val)
??????return?string.Format(“0{0:X}“?val);
????static?string?toArcSymbolTypeString(int?val)
??????switch?(val)
????????case?0:?return?“Precedes?text“;
????????case?1:?return?“Above?text“;
????????case?2:?return?“None“;
??????return?“???“;
????/*?Shorten?a?path?with?ellipses.????????????????????????????????????????*/
????static?string?shortenPath(string?Inpath?int?maxPath)
??????string?path?=?Inpath;
??????/*?If?the?path?fits?just?return?it???????????????????????????????????*/
??????if?(path.Length?<=?maxPath)
????????return?path;
??????/*?If?there‘s?no?backslash?just?truncate?the?path????????????????????*/
??????int?lastBackslash?=?path.LastIndexOf(‘\\‘);
??????if?(lastBackslash?0)
????????return?path.Substri
?????文件???12713759??2010-04-22?12:07??TNETCHM\TDNET.chm
?????文件????1030883??2017-04-25?14:00??TNETCHM\TDNET.chw
?????文件???17508864??2010-05-08?14:44??TX_3.03\TDXSetup.msi
?????文件???12101595??2009-04-05?22:36??DWGdirectXVB.chm
?????文件??????96256??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\AcIdViewObj_3.03_9.tx
?????文件??????64000??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\AsdkSmileyDb_3.03_9.tx
?????文件??????73216??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\AutoSurfServices_3.03_9.tx
?????文件?????169472??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\DbCommands_3.03_9.tx
?????文件?????576000??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\DbConstraints_3.03_9.tx
?????文件?????730112??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\DWFCore.dll
?????文件????2529792??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\DWFToolkit.dll
?????文件?????658432??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\ExCustObjs_3.03_9.tx
?????文件??????35840??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\ExDynamicBlocks_3.03_9.tx
?????文件??????28672??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\ExEvalWatchers_3.03_9.tx
?????文件??????47104??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\ExFieldEvaluator_3.03_9.tx
?????文件??????22528??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\FileDlgExt_3.03_9.dll
?????文件?????104448??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\GripPoints_3.03_9.tx
?????文件?????100864??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\ModelerGeometry_3.03_9.tx
?????文件??????28160??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\OdBagFiler_3.03_9.tx
?????文件??????40960??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\OdCurveFunctions_3.03_9.tx
?????文件??????20992??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\OdOleItemHandler_3.03_9.tx
?????文件??????25088??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\OpenCadTx_3.03_9.tx
?????文件??????47616??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\PlotSettingsValidator_3.03_9.tx
?????文件??????49664??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\Plotst
?????文件??????25600??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\RasterProcessor_3.03_9.tx
?????文件?????297472??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\RecomputeDimBlock_3.03_9.tx
?????文件?????115200??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\RxRasterServices_3.03_9.tx
?????文件?????637952??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\TD_AcisBuilder_3.03_9.dll
?????文件??????10240??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\TD_Alloc_3.03_9.dll
?????文件?????291328??2010-04-29?06:21??TNET_3_03\Teigha_NET_3_03\bin\TD_Ave_3.03_9.tx
............此處省略412個(gè)文件信息
