  • 大小: 10.8MB
    發(fā)布日期: 2022-03-29
  • 標簽: .NET??WMS??庫存管理??
VB.NET做的庫存管理系統(tǒng),涉及采購、銷售、生產、盤點。包含庫存流水
using?System;
using?System.Data;
using?System.Configuration;
using?System.Collections;
using?System.Web;
using?System.Web.Security;
using?System.Web.UI;
using?System.Web.UI.WebControls;
using?System.Web.UI.WebControls.WebParts;
using?System.Web.UI.HtmlControls;
using?System.Data.SqlClient;
public?partial?class?AddCangku?:?System.Web.UI.Page
????protected?void?Page_Load(object?sender?EventArgs?e)
????protected?void?Button1_Click(object?sender?EventArgs?e)
????????if?(kong())
????????????//定義變量
????????????string?aa?bb?cc;
????????????aa?=?this.TextBox1.Text;
????????????bb?=?this.TextBox2.Text;
????????????cc?=?this.TextBox5.Text;
????????????SqlConnection?scon?=?new?SqlConnection(ConfigurationManager.AppSettings[“ConnectionString“]);
????????????scon.Open();
????????????SqlCommand?scmd?=?new?SqlCommand(“insert?into?cangku(Nameckbmbeizhu)?values?(‘“?+?aa?+?“‘‘“?+?bb?+?“‘‘“?+?cc?+?“‘)“?scon);
????????????scmd.ExecuteNonQuery();
????????????scmd.Dispose();
????????????scon.Close();
????????????Response.Write(“ript?language=‘javascript‘>alert(‘添加成功!‘);ript>“);
????????????Server.Transfer(“manageCangku.aspx“);
????private?bool?kong()
????????if?(this.TextBox1.Text?==?““)
????????????Response.Write(“ript?language=‘javascript‘>alert(‘倉庫名稱不能為空!‘);ript>“);
????????????return?false;
????????else
????????????if?(this.TextBox2.Text?==?““)
????????????????Response.Write(“ript?language=‘javascript‘>alert(‘倉庫編碼不能為空!‘);ript>“);
????????????????return?false;
????????????else
????????????????return?true;
????protected?void?Button2_Click(object?sender?EventArgs?e)
?????文件????1015808??2009-10-22?02:37??庫存管理\db\Empty.db
?????文件????1015808??2010-04-11?23:34??庫存管理\db\storage.db
?????文件??????69632??2006-07-04?11:53??庫存管理\FT_ET99_API.dll
?????文件????1712128??2006-12-20?13:47??庫存管理\GdiPlus.dll
?????文件????7930204??2010-04-11?22:58??庫存管理\gtstorageTXM.exe
?????文件???????2318??2007-05-02?08:58??庫存管理\kc\AddCangku.aspx
?????文件???????1938??2007-05-02?14:39??庫存管理\kc\AddCangku.aspx.cs
?????文件???????4978??2007-05-02?12:21??庫存管理\kc\Addchuku.aspx
?????文件???????3291??2007-05-02?14:39??庫存管理\kc\Addchuku.aspx.cs
?????文件???????2586??2007-05-02?08:53??庫存管理\kc\Addghdw.aspx
?????文件???????2042??2007-05-02?14:39??庫存管理\kc\Addghdw.aspx.cs
?????文件???????4550??2007-05-02?09:13??庫存管理\kc\Addhuo.aspx
?????文件???????4724??2007-05-02?14:39??庫存管理\kc\Addhuo.aspx.cs
?????文件???????3280??2007-05-02?08:58??庫存管理\kc\Addpancun.aspx
?????文件???????2654??2007-05-02?14:39??庫存管理\kc\Addpancun.aspx.cs
?????文件???????2428??2007-05-02?08:55??庫存管理\kc\AddPeople.aspx
?????文件???????1925??2007-05-02?14:40??庫存管理\kc\AddPeople.aspx.cs
?????文件???????4768??2007-05-02?10:23??庫存管理\kc\Addruku.aspx
?????文件???????3214??2007-05-02?14:40??庫存管理\kc\Addruku.aspx.cs
?????文件???????2589??2007-05-02?08:55??庫存管理\kc\Addshdw.aspx
?????文件???????2046??2007-05-02?14:38??庫存管理\kc\Addshdw.aspx.cs
?????文件????1179648??2008-03-29?15:36??庫存管理\kc\App_Data\kc_db_Data.MDF
?????文件????1048576??2008-03-29?15:38??庫存管理\kc\App_Data\kc_db_Log.LDF
?????文件????????410??2002-12-30?01:40??庫存管理\kc\chinaz.com.txt
?????文件???????4087??2007-05-02?13:02??庫存管理\kc\chukujetongji.aspx
?????文件???????2584??2007-05-02?12:05??庫存管理\kc\chukujetongji.aspx.cs
?????文件???????4071??2007-05-02?13:57??庫存管理\kc\ckndtj.aspx
?????文件???????2579??2007-05-02?13:59??庫存管理\kc\ckndtj.aspx.cs
?????文件???????2453??2007-05-01?18:28??庫存管理\kc\Editcangku.aspx
?????文件???????3215??2007-05-02?14:40??庫存管理\kc\Editcangku.aspx.cs
............此處省略78個文件信息
