  • 大小: 103.92MB
    發布日期: 2022-02-23
  • 標簽: vb.net源碼??
VB.NET入門經典(第三版)含源代碼勾月科技。內容詳細且易懂,是一本非常優秀全面的書籍。
using?System.Reflection;
using?System.Runtime.CompilerServices;
//?General?Information?about?an?assembly?is?controlled?through?the?following?
//?set?of?attributes.?Change?these?attribute?values?to?modify?the?information
//?associated?with?an?assembly.
[assembly:?Assemblytitle(““)]
[assembly:?AssemblyDescription(““)]
[assembly:?AssemblyConfiguration(““)]
[assembly:?AssemblyCompany(““)]
[assembly:?AssemblyProduct(““)]
[assembly:?AssemblyCopyright(““)]
[assembly:?AssemblyTrademark(““)]
[assembly:?AssemblyCulture(““)]
//?Version?information?for?an?assembly?consists?of?the?following?four?values:
//??????Major?Version
//??????Minor?Version?
//??????Build?Number
//??????Revision
//?You?can?specify?all?the?values?or?you?can?default?the?Revision?and?Build?Numbers?
//?by?using?the?‘*‘?as?shown?below:
[assembly:?AssemblyVersion(“1.0.*“)]
//?In?order?to?sign?your?assembly?you?must?specify?a?key?to?use.?Refer?to?the?
//?Microsoft?.NET?framework?documentation?for?more?information?on?assembly?signing.
//?Use?the?attributes?below?to?control?which?key?is?used?for?signing.?
//?Notes:?
//???(*)?If?no?key?is?specified?the?assembly?is?not?signed.
//???(*)?KeyName?refers?to?a?key?that?has?been?installed?in?the?Crypto?Service
//???????Provider?(CSP)?on?your?machine.?KeyFile?refers?to?a?file?which?contains
//???????a?key.
//???(*)?If?the?KeyFile?and?the?KeyName?values?are?both?specified?the?
//???????following?processing?occurs:
//???????(1)?If?the?KeyName?can?be?found?in?the?CSP?that?key?is?used.
//???????(2)?If?the?KeyName?does?not?exist?and?the?KeyFile?does?exist?the?key?
//???????????in?the?KeyFile?is?installed?into?the?CSP?and?used.
//???(*)?In?order?to?create?a?KeyFile?you?can?use?the?sn.exe?(Strong?Name)?utility.
//???????When?specifying?the?KeyFile?the?location?of?the?KeyFile?should?be
//???????relative?to?the?project?output?directory?which?is
//???????%Project?Directory%\obj\.?For?example?if?your?KeyFile?is
//???????located?in?the?project?directory?you?would?specify?the?AssemblyKeyFile?
//???????attribute?as?[assembly:?AssemblyKeyFile(“..\\..\\mykey.snk“)]
//???(*)?Delay?Signing?is?an?advanced?option?-?see?the?Microsoft?.NET?framework
//???????documentation?for?more?information?on?this.
[assembly:?AssemblyDelaySign(false)]
[assembly:?AssemblyKeyFile(““)]
[assembly:?AssemblyKeyName(““)]
?????目錄???????????0??2013-01-28?11:08??20141101-VB.NET入門經典(第三版)\
?????目錄???????????0??2013-01-15?14:56??20141101-VB.NET入門經典(第三版)\code\
?????目錄???????????0??2014-11-01?10:11??20141101-VB.NET入門經典(第三版)\code\559923?code02\
?????目錄???????????0??2004-04-05?22:29??20141101-VB.NET入門經典(第三版)\code\559923?code02\ProVB.NET\
?????文件????????1044??2004-02-09?00:01??20141101-VB.NET入門經典(第三版)\code\559923?code02\ProVB.NET\AssemblyInfo.vb
?????文件????????7016??2004-02-09?00:43??20141101-VB.NET入門經典(第三版)\code\559923?code02\ProVB.NET\Form1.resx
?????文件????????2028??2004-04-05?22:19??20141101-VB.NET入門經典(第三版)\code\559923?code02\ProVB.NET\Form1.vb
?????文件?????????903??2004-02-09?00:01??20141101-VB.NET入門經典(第三版)\code\559923?code02\ProVB.NET\ProVB.NET.sln
?????文件????????8704??2004-04-05?22:19??20141101-VB.NET入門經典(第三版)\code\559923?code02\ProVB.NET\ProVB.NET.suo
?????文件????????4206??2004-02-09?00:01??20141101-VB.NET入門經典(第三版)\code\559923?code02\ProVB.NET\ProVB.NET.vbproj
?????文件????????1813??2004-04-05?22:19??20141101-VB.NET入門經典(第三版)\code\559923?code02\ProVB.NET\ProVB.NET.vbproj.user
?????目錄???????????0??2014-11-01?10:11??20141101-VB.NET入門經典(第三版)\code\559923?code03\
?????目錄???????????0??2004-04-05?22:15??20141101-VB.NET入門經典(第三版)\code\559923?code03\AttributeDemo\
?????文件????????1148??2002-02-05?17:56??20141101-VB.NET入門經典(第三版)\code\559923?code03\AttributeDemo\AssemblyInfo.vb
?????文件?????????911??2004-04-05?22:10??20141101-VB.NET入門經典(第三版)\code\559923?code03\AttributeDemo\AttributeDemo.sln
?????文件????????8192??2004-04-05?22:13??20141101-VB.NET入門經典(第三版)\code\559923?code03\AttributeDemo\AttributeDemo.suo
?????文件????????3605??2004-04-05?22:10??20141101-VB.NET入門經典(第三版)\code\559923?code03\AttributeDemo\AttributeDemo.vbproj
?????文件????????1814??2004-04-05?22:13??20141101-VB.NET入門經典(第三版)\code\559923?code03\AttributeDemo\AttributeDemo.vbproj.user
?????文件?????????584??2004-04-05?22:13??20141101-VB.NET入門經典(第三版)\code\559923?code03\AttributeDemo\Module1.vb
?????目錄???????????0??2004-04-05?22:14??20141101-VB.NET入門經典(第三版)\code\559923?code03\GenerationsDemo\
?????文件????????1155??2002-02-05?17:51??20141101-VB.NET入門經典(第三版)\code\559923?code03\GenerationsDemo\AssemblyInfo.vb
?????文件?????????915??2004-04-05?22:13??20141101-VB.NET入門經典(第三版)\code\559923?code03\GenerationsDemo\GenerationsDemo.sln
?????文件????????7680??2004-04-05?22:14??20141101-VB.NET入門經典(第三版)\code\559923?code03\GenerationsDemo\GenerationsDemo.suo
?????文件????????3611??2004-04-05?22:13??20141101-VB.NET入門經典(第三版)\code\559923?code03\GenerationsDemo\GenerationsDemo.vbproj
?????文件????????1815??2004-04-05?22:14??20141101-VB.NET入門經典(第三版)\code\559923?code03\GenerationsDemo\GenerationsDemo.vbproj.user
?????文件?????????326??2004-04-05?22:14??20141101-VB.NET入門經典(第三版)\code\559923?code03\GenerationsDemo\Module1.vb
?????目錄???????????0??2014-11-01?10:11??20141101-VB.NET入門經典(第三版)\code\559923?code04\
?????目錄???????????0??2004-04-05?22:02??20141101-VB.NET入門經典(第三版)\code\559923?code04\Boolean\
?????文件????????1028??2002-02-06?10:31??20141101-VB.NET入門經典(第三版)\code\559923?code04\Boolean\AssemblyInfo.vb
?????文件?????????899??2004-04-05?21:55??20141101-VB.NET入門經典(第三版)\code\559923?code04\Boolean\Boolean.sln
?????文件????????8192??2004-04-05?22:02??20141101-VB.NET入門經典(第三版)\code\559923?code04\Boolean\Boolean.suo
............此處省略1586個文件信息
