  • 大小: 275KB
    發布日期: 2021-06-04
  • 標簽: VB.net??
簡單的學生信息管理系統,實現查詢,統計,修改等功能,適合初學者。。
#region?Using?directives
using?System;
using?System.Diagnostics;
using?System.Drawing;
using?System.IO;
using?System.Reflection;
using?System.Security;
using?WebControls?=?System.Web.UI.WebControls;
using?HTMLControls?=?System.Web.UI.HtmlControls;
using?WinForms?=?System.Windows.Forms;
using?SQLTypes?=?System.Data.SqlTypes;
#endregion
//?mscorlib
[assembly:?DebuggerDisplay(@“\{Name?=?{Name}?FullName?=?{FullName}}“?Target?=?typeof(Type))]
//?System.Drawing
[assembly:?DebuggerDisplay(@“\{Name?=?{fontFamily.Name}?Size={fontSize}}“?Target?=?typeof(Font))]
[assembly:?DebuggerDisplay(@“\{Name?=?{name}}“?Target?=?typeof(FontFamily))]
[assembly:?DebuggerDisplay(@“\{Color?=?{color}}“?Target?=?typeof(Pen))]
[assembly:?DebuggerDisplay(@“\{X?=?{x}?Y?=?{y}}“?Target?=?typeof(Point))]
[assembly:?DebuggerDisplay(@“\{X?=?{x}?Y?=?{y}}“?Target?=?typeof(PointF))]
[assembly:?DebuggerDisplay(@“\{X?=?{x}?Y?=?{y}?Width?=?{width}?Height?=?{height}}“?Target?=?typeof(Rectangle))]
[assembly:?DebuggerDisplay(@“\{X?=?{x}?Y?=?{y}?Width?=?{width}?Height?=?{height}}“?Target?=?typeof(RectangleF))]
[assembly:?DebuggerDisplay(@“\{Width?=?{width}?Height?=?{height}}“?Target?=?typeof(Size))]
[assembly:?DebuggerDisplay(@“\{Width?=?{width}?Height?=?{height}}“?Target?=?typeof(SizeF))]
[assembly:?DebuggerDisplay(@“\{Color?=?{color}}“?Target?=?typeof(SolidBrush))]
//?System.Web.UI.WebControls
[assembly:?DebuggerDisplay(@“\{Text?=?{Text}}“?Target?=?typeof(WebControls::Button))]
[assembly:?DebuggerDisplay(@“\{Text?=?{Text}}“?Target?=?typeof(WebControls::Label))]
[assembly:?DebuggerDisplay(@“\{Text?=?{Text}}“?Target?=?typeof(WebControls::Hyperlink))]
[assembly:?DebuggerDisplay(@“\{Text?=?{Text}?Checked?=?{Checked}}“?Target?=?typeof(WebControls::CheckBox))]
[assembly:?DebuggerDisplay(@“\{Text?=?{Text}?Checked?=?{Checked}}“?Target?=?typeof(WebControls::RadioButton))]
[assembly:?DebuggerDisplay(@“\{SelectedDate?=?{SelectedData}}“?Target?=?typeof(WebControls::Calendar))]
[assembly:?DebuggerDisplay(@“\{Text?=?{Text}}“?Target?=?typeof(WebControls::linkButton))]
//?System.Web.UI.HtmlControls
[assembly:?DebuggerDisplay(@“\{Value?=?{Value}}“?Target?=?typeof(HTMLControls::HtmlInputButton))]
[assembly:?DebuggerDisplay(@“\{InnerText?=?{InnerText}}“?Target?=?typeof(HTMLControls::HtmlGenericControl))]
[assembly:?DebuggerDisplay(@“\{Value?=?{Value}}“?Target?=?typeof(HTMLControls::HtmlTextArea))]
[assembly:?DebuggerDisplay(@“\{Value?=?{Value}}“?Target?=?typeof(HTMLControls::HtmlInputText))]
[assembly:?DebuggerDisplay(@“\{Value?=?{Value}?Checked?=?{Checked}}“?Target?=?typeof(HTMLControls::HtmlInputCheckBox))]
[assembly:?DebuggerDisplay(@“\{Value?=?{Value}?Checked?=?{Checked}}“?Target?=?typeof(HTMLControls::HtmlInputRadioButton))]
//?System.Windows.Forms
[assembly:?DebuggerDisplay(@“\{ExecutablePath?=?{executablePath}}“?Target?=?typeof(WinForms::Application))]
[assembly:?DebuggerDisplay(@“\{Text?=?{Text}}“?Target?=?typeof(WinForm
?????文件???????2627??2011-06-24?17:35??20080854130\help.htm
?????文件?????667648??2011-06-24?17:44??20080854130\student.mdb
?????文件??????50684??2011-06-24?17:02??20080854130\Visual?Studio?2005\Visualizers\attribcache80.bin
?????文件???????9930??2005-11-11?22:50??20080854130\Visual?Studio?2005\Visualizers\autoexp.cs
?????文件??????15872??2005-11-11?22:50??20080854130\Visual?Studio?2005\Visualizers\autoexp.dll
?????文件???????8277??2005-11-11?22:50??20080854130\Visual?Studio?2005\Visualizers\autoexpce.cs
?????文件??????12288??2005-11-11?22:50??20080854130\Visual?Studio?2005\Visualizers\autoexpce.dll
?????文件??????15093??2012-03-08?19:56??20080854130\管理信息系統—朱玉鳳—130\addM.Designer.vb
?????文件???????5814??2012-03-08?19:55??20080854130\管理信息系統—朱玉鳳—130\addM.resx
?????文件???????4465??2012-03-08?19:55??20080854130\管理信息系統—朱玉鳳—130\addM.vb
?????文件??????98304??2012-03-08?19:56??20080854130\管理信息系統—朱玉鳳—130\bin\Debug\管理信息系統.exe
?????文件?????183808??2012-03-08?19:56??20080854130\管理信息系統—朱玉鳳—130\bin\Debug\管理信息系統.pdb
?????文件???????5632??2005-12-08?14:51??20080854130\管理信息系統—朱玉鳳—130\bin\Debug\管理信息系統.vshost.exe
?????文件????????657??2012-03-08?19:56??20080854130\管理信息系統—朱玉鳳—130\bin\Debug\管理信息系統.xml
?????文件???????2706??2012-03-08?19:55??20080854130\管理信息系統—朱玉鳳—130\claM.Designer.vb
?????文件???????5814??2012-03-08?19:55??20080854130\管理信息系統—朱玉鳳—130\claM.resx
?????文件????????903??2012-03-08?19:55??20080854130\管理信息系統—朱玉鳳—130\claM.vb
?????文件???????2749??2012-03-08?19:55??20080854130\管理信息系統—朱玉鳳—130\code.Designer.vb
?????文件???????5814??2012-03-08?19:55??20080854130\管理信息系統—朱玉鳳—130\code.resx
?????文件????????893??2012-03-08?19:55??20080854130\管理信息系統—朱玉鳳—130\code.vb
?????文件???????7757??2012-03-08?19:55??20080854130\管理信息系統—朱玉鳳—130\count.Designer.vb
?????文件???????6005??2012-03-08?19:55??20080854130\管理信息系統—朱玉鳳—130\count.resx
?????文件???????6000??2012-03-08?19:55??20080854130\管理信息系統—朱玉鳳—130\count.vb
?????文件???????2718??2012-03-08?19:55??20080854130\管理信息系統—朱玉鳳—130\dept.Designer.vb
?????文件???????5814??2012-03-08?19:55??20080854130\管理信息系統—朱玉鳳—130\dept.resx
?????文件????????891??2012-03-08?19:55??20080854130\管理信息系統—朱玉鳳—130\dept.vb
?????文件???????7244??2012-03-08?19:51??20080854130\管理信息系統—朱玉鳳—130\Form1.Designer.vb
?????文件???????6012??2012-03-08?19:51??20080854130\管理信息系統—朱玉鳳—130\Form1.resx
............此處省略67個文件信息
